I'm 99% sure I know the answer, but just to be 100% sure here's the question.
I will be setting up a new subwoofer this week. It is a Revel Concerta2 B10, and I will be connecting it to a Sony STR-AZ5000ES pre-out. My current sub had one of the RCA inputs labeled LFE and the manual said to use a single RCA cable from the amp to the sub, but the B10 manual only discusses a 2 channel connection. So:
Am I correct in that I can connect a single RCA cable from the Sony pre-out to either the red or white input on the back of the B10?
Is there any advantage to using a Y connector to connect to both the red and white input on the B10?
