Hi folks,
I recently purchased the Khadas Tone Board and JDS Atom amp thanks to ASR.
I've noticed a bit of an anomaly on Windows 10 that's puzzling me. Perhaps others using Windows 10 can confirm this.
There's a significant change in the playback speed of the Windows "Test" tone, as the Sample Rate is increased. There is a progressive increase all the way from 44.1Khz through 384Khz, where 44.1Khz is very "rushed" while 384Khz is slower/clearer. 44.1Khz also has a few "pops" associated with it. I do not remember this happening with my Essence STX, but my memory fails me.
The above can be configured by navigating as follows: Control Panel > Hardware and Sound > Sound > Playback Tab > Khadas Tone Control > Advanced > Test (button)
I cannot make out any significant differences in regular audio playback so I doubt this affects anything. Nevertheless, it is curious that sampling rate affects the test tone alone.
Configuration (only adding what I think is relevant - can add more as required):
- Windows 10
- KTB connected only via USB
Questions:
1) Is this happening on your Windows 10 machines as well? Please share the DAC you used as well
2) What are some possible reasons for this?
3) Is it better to set the highest possible sample rate for the KTB? (I've heard that it's better to match sample rate to the source audio)
- Windows 10
Questions:
