Announcing beta-test of PKHarmonic VST plugin
Yes, bypass works, too. I can't help with EQU graph display -- it's obviously incorrect. There is no clipping. Here's white noise and frequency response using those same settings I used above with PKHarmonic enabled:
And here's with the bypass button engaged. Note that I'm using a 96k recording auto-resampled by Windows to 48k, which explains some of the extra harmonics you see below -140dB, but clearly, PKHarmonic is bypassed:
Thank you for your confirmation. It's not easy to ignore the red clipping graph that looks as high as the Himalayas in front of you, but I'll try to ignore it. =)
