Announcement: A new kid on the block, introducing Osmium Sound
Making use of older gear is A Good Thing compared to trashing it.
Especially for testing to see if a project meets your needs.
Once "in production" things can be upgraded if energy efficiency is important to you.
I am not opposed to re-use older gear. Just saying pre 2010 pc/laptops were less power efficient. Sure they can be used for testing but if you plan to leave Osmium running during the day factor in the power usage long term. Of course views might differ as we don't face the same electricity prices, run solar panels or not, have electronic garbage that ends up in the landfill instead or being recycled for rare metals etc. etc.
Use of older gear is for sure interesting, but we are now facing availability of very interesting industrial surplus in form of fanless thin clients that for a super reasonable cost allows to provide more energy efficient setups with much better performance. Reuse of this type of hardware is also a virtuous example of circular economy!
Ale
if a wifi network is known and the cable disconnected it should go wifi otherwise if the cable disconnects and no wifi is saved, it shows an access point with that net. If you connect to it it will show a page to scan and set a wifi network
I get mixed results. On the Surface it never goes to the Saved WiFi connection but ends up on the 10.42.0.1. On the mini sometimes Saved WiFi sometimes 10.42.0.1. This is by pulling the network cable. It is very fast in detecting connection is lost.
I am not sure what Osmium's Network Configuration does. Looks like it displays last known config and that only a Reload Data forces it to check what the actual state is.
Maybe put a message somewhere that A Restore from file will restart the device.
ok i will take a note and correct it in the next release. for the message on the restore yes i will include it.
Through the Lyrion interface one can move a player to another server. Could the same be done via the Osmium interface or are there technical issues?
Not at the moment. You can only do it via the kiosk ui by changing the external lyrion server so you can only do it for the local player.
Perhaps expand that info and show type CPU, amount of RAM, does pc have wired/wireless/bluetooth, local disks etc. Not everybody knows all their hardware specs. Might help with troubleshooting too.
I made a 2nd attempt (hence the (2) in the folder name) to paste a folder from a network share to the"Music on this player". After the "Paste here" it shows the progress of copying. Next I decided to remove the older NewAudioPop folder and that worked flawless but you loose the copying progress info. I can see folders are still added so copying is still in progress.
Not a huge problem unless you shut down Osmium. Perhaps have a warning when you try to shutdown Osmiun that:
- a file copy is in progress
- the library hasn't fully updated
- other actions????
There is probably a reason for creating a "foldername (2)" instead of asking to replace "foldername". I guess this way control is more up to the user.
That works in the Osmium interface but not in the Webadmin interface. No options to add.
Sorry I should have made it clearer. The "Add one below" part makes sense in the top Osmium interface but not so much in the Webadmin interface as there is no option below.
Not a big issue. Just trying to prevent potential confusion.
sudo systemctl status lyrionmusicserver.service
○ lyrionmusicserver.service - Lyrion Music Server
Loaded: loaded (/usr/lib/systemd/system/lyrionmusicserver.service; enabled; preset: enabled)
Active: inactive (dead) since Fri 2026-10-09 20:48:14 CEST; 48s ago
Duration: 536ms
Invocation: d02b3dc5195c420aa48995c66f0583f5
Process: 5477 ExecStart=/usr/sbin/squeezeboxserver --prefsdir $PREFSDIR --logdir $LOGDIR --cachedir $CACHEDIR --charset $CHARSET $SLIMOPTIONS (code=exited, status=>
Main PID: 5477 (code=exited, status=0/SUCCESS)
IO: 0B read, 0B written
Mem peak: 75.3M
CPU: 503ms
Oct 09 20:48:14 mini systemd[1]: Started lyrionmusicserver.service - Lyrion Music Server.
Oct 09 20:48:14 mini squeezeboxserver[5477]: Unable to read prefs from /var/lib/squeezeboxserver/prefs/server.prefs : Usage: YAML::XS::LibYAML::Load(yaml_sv) at /usr/s>
Oct 09 20:48:14 mini squeezeboxserver[5477]: Cannot write to '/var/log/squeezeboxserver/server.log': No space left on device at /usr/share/squeezeboxserver/CPAN/Log/Lo>
Oct 09 20:48:14 mini systemd[1]: lyrionmusicserver.service: Deactivated successfully.
Oct 09 20:48:14 mini systemd[1]: lyrionmusicserver.service: Consumed 503ms CPU time, 75.3M memory peak.
While testing the file manager I put too many audio files on the combined /home /var /data partition and no more space was left. Lyrion was not happy..... ;)
Perhaps put /var on a separate partition or give a warning when the combined /home /var /data partition reaches 99% of its capacity.
As this might be a situation that people use the Factory Reset and Refresh option maybe check if there is enough free space. There was a message about a problem installing Material Skin when I did the Refresh.
I just report and yes users can break more stuff than developers anticipate....
Really nice feature to hop through the cross referenced info (is that the correct term) and dive into artists/members/albums/bands. If you go too deep the Back button (top right) is overflowing with text. The Back button still works so only a visual issue.
Looks like the 500GB SD Card in my Surface Go doesn't get auto-mounted and appear as Internal Disk. Is that as intended/by design?
Yes I can add it as a source but then it gets automatically shared.
It depends on how debian labels it at the kernel level, probably on the surface it is seen as an hdd. Can you give me a support zip with the sdcard inserted?
Only the top half of the text with the details of the first share is visible.
