I got it from Audiophonics.fr (I think the only shop that sells them). It was slightly cheaper for me there then to order a Singxer F-1 and I know the support and returns are good at Audiophonics. Btw, I'm located in The Netherlands.From what shop you get the Armature Hecate if I can ask ?
I understand your comment abt. the subjective sensation of sound improvement via the USB/SPDIF bridge ...
Each time I say the same I get fired on my back, fact which is also understandable as there is no support on it from an engineering standpoint ...
My Topping DX7s is now the 3rd DAC in the row I am keeping feeding via my Weiss INT204 USB to S/PDIF interface, after the Teac 501 and the NAD M51.
3 on 3 so 100% is too much to be just an occasional feeling, IMHO ...
OK the Teac 501 was not very good at the USB infeed, but the M51 as well as the DX7s are both supposed to be.
Yep, that's supposed to be exactly the same as the USB input on the D2 DAC. So that wouldn't be a good buy probably.. (though the Armature Hecate is 200 euro)Anedio : there is an Anedio U2 interface on sale at my local Craigslist for abt. 90 EUR ... including all sort of SPDIF' adapters
I'd try it out. Armature Hecate (not the "LT" version). If it isn't equal (or who knows perhaps even better) than the Weiss then return it for free within two weeksI am holding off several purchasing proposals for my Weiss INT204 each time I put it on sale just for fun on my local Craigslist ... that maybe 1 day I may wish to sell it sooner or later for a cheaper solution like the Singxers ... and buy a new road bicycle with the huge saving ...
https://www.audiophonics.fr/fr/inte...s-xcore-208-usb-spdif-asynchrone-p-11412.html
Yes it's powered by USB. But at the same time it's also galvanically isolated from USB power (the only one that does this double isolation of both data and power I think). How exactly this works I have no clueWhy not ? It looks exactly a F-1, I have read Singxer does some OEM assembling, so this is one is a good example.
How do you power the unit ? Taking the 5V directly from the PC USB ?
That was in fact the only "point" for which I was unsure abt. adopting a F-1 alike solution ...
MOTU 624 has one of the best analog loopback result I've ever seen and it is much cheaper than ADI-2 Pro FS.
http://prosound.ixbt.com/interfaces/motu-624.shtml
http://prosound.ixbt.com/interfaces/motu/624/2444.shtml
Actually.. My bad, I had another look and there are no measurements of the D2 USB input.
The measurements are of the D2 S/PDIF input.
https://web.archive.org/web/20161206045028/http://www.anedio.com:80/index.php/product/d2_measure (under jitter).
With a master clock jitter of 0.5 ps rms.
I can't find specs for the USB input, but read somewhere it's the same as their U2 USB to S/PDIF converter. I can't find any measurements of this but it's claimed spec is 20 ps rms. This is 40 times the master clock jitter of the D2 DAC. https://web.archive.org/web/2016101...edio.com/index.php/product/usb2_specfications Anyhow this is an old product where the DAC is so good it's still up to current spec but aparently the USB input is not..
As for the Armature Hecate it should outperform both. It is a next generation product with the best next generation chips, drivers and clocks available (crystek cchd-575). So perhaps I should not have been surprised to hear a difference..
Btw I have good ears, especially for a 41 year old. But this isn't some super hearing thing. I wish I had a good ADC laying around so I could record the difference and do a proper ABX in foobar2000. But even by uploading it it would show you all that the difference is readily audible. Alas, no good ADC here now.
