STC
Thanks. are you referring to the charts previously posted here?Yes. It measures from the in ear microphones. That does make it a little bit different of a measurement.
No. I have the BACCH4Mac. Referring to the measurements taken when I launch a new filterThanks. are you referring to the charts previously posted here?
I think someone else posted those measurements here but aren’t they simulated and not the actual response? I will add the link here ….No. I have the BACCH4Mac. Referring to the measurements taken when I launch a new filter
That’s the actual responseI think someone else posted those measurements here but aren’t they simulated and not the actual response? I will add the link here ….
Edit:-
Post in thread 'BACCH and other XTC'
https://audiosciencereview.com/forum/index.php?threads/bacch-and-other-xtc.47755/post-1711395
That’s my measurements and it’s the simulated result. I was just shown how to make a measurement of the BACCH filter and the program graphically compares the results in the same format as the screenshot.That’s the actual response
In the chart, the solid lines represent simulated values. The dashed lines which supposed to represent the measured values are not there. This is white noise and actual measurement at ears cannot be flat.Here’s an example of an actual set of measurements from the BACCH4Mac
What makes you think they are simulated? How would the BACCH simulate a frequency response? I know memory is unreliable but Edgar talked at some length about that measurement and made no mention of it not being an actual measurement. And the measurements are pretty far from flatIn the chart, the solid lines represent simulated values. The dashed lines which supposed to represent the measured values are not there. This is white noise and actual measurement at ears cannot be flat.
The top portion is actual measurement but the bottom one is what I am interested. Ears as such that frequency at ear canal cannot be flat due to pinna. So what are those lines? Why it is flat?What makes you think they are simulated? How would the BACCH simulate a frequency response? I know memory is unreliable but Edgar talked at some length about that measurement and made no mention of it not being an actual measurement. And the measurements are pretty far from flat
Maybe the numbers are deceptive. It’s not flat. It turns into a roller coaster at around 2khzThe top portion is actual measurement but the bottom one is what I am interested. Ears as such that frequency at ear canal cannot be flat due to pinna. So what are those lines? Why it is flat?
As an EE and 30 years as a recording engineer I understand exactly how it works. Crosstalk cancellation is nothing new. Its an effect, like EQ or compression or artificial reverb. It CHANGES the sound. How can you deny that, Dunning.He's a classic Dunning-Kruger. He doesn't understand what BACCH does, thinks it is some kind of sound effect. If anybody is interested, there are a few write-ups on BACCH technology in Archimago's blog here and here, and more info on Theoretica's website about how it works. There is also an easy to digest wikipedia article. Plenty of resources to look at. There is real science involved, this is not some mere effects plugin.
Very impressive numbers.Here’s an example of an actual set of measurements from the BACCH4Mac
You are not the first EE or recording engineer to say so. There was another Grammy winner audio engineer had the same opinion but thankfully he was in Spatial Audio forum where he was corrected by an eminent member of the topic. Sound effect is what you do to the signal before coming out the speakers. Crosstalk cancellation deals with the sound after coming out from the speakers. There were many AES papers on this topic. The was an institute which was part of AES technical tour.As an EE and 30 years as a recording engineer I understand exactly how it works. Crosstalk cancellation is nothing new. Its an effect, like EQ or compression or artificial reverb. It CHANGES the sound. How can you deny that, Dunning.
It doesn’t “change” the sound. It prevents the cross talk from damaging the sound. It is objectively more accurate.As an EE and 30 years as a recording engineer I understand exactly how it works. Crosstalk cancellation is nothing new. Its an effect, like EQ or compression or artificial reverb. It CHANGES the sound. How can you deny that, Dunning.
