Sharok
- Joined
- Sep 22, 2022
- Messages
- 60
- Likes
- 7
What’s the maximum output sampling rate after applying ORC?I have a pair of Polk L800's and just Demo'd the BACCH-SP Appliance at Axpona 2024. I spent most of my time in that room. The L800's had a wider sound stage which is likely because they are projecting sound outward AND because I have to toe-in the L800's a bit because I have them farther apart (7'). The BACCH-SP was more immersive and had head tracking.
However, The BACCH-SP set up was
XTC is fickle and worth every inconvenience but requires a lot of experimentation which I've found very rewarding for this hobby.
- speakers were closer together than my L800's 5' vs 7'
- speakers were closer to the listening position 4' vs 8'
- I'm sure he was using very directional speakers where as I'm unsure of the directionality of the L800's
- His room was untreated and small, my room is treated fairly well
- he very modestly "treated" the hotel room side walls (like 2" absorbers or less) vs I do not treat my side walls;
- However, I have 16 2'x2' 4" absorbers on my back wall
- His seats had space behind them vs I'm close to the wall
- His seats had no headrest, mine have a head rest
I tried the uBACCH VST version and was not able to make it sound better or even very effective but perhaps I was listening for the wrong things. I also had someone convolve a track and gave him dimensions and it did not work well. I'm left to assume that the VST is simply not as good as BACCH4MAC/BACCH-SP or my room is not as good for BACCH4MAC/BACCH-SP.
Problem with experimenting is that I'd have to buy and set up a Mac Mini plus buy $1000 in software OR if I really do need the upgrade for measurements (which I like the idea of measuring XTC, I haven't figured out how to do that in REW) then I'm looking at a $740 restock fee if it doesn't work as well.
I'm a home theater guy and fitting that into a home theater chain would be difficult. The BACCH-SP (despite being out of my budget) has estimated 30ms of latency (per Edgars guess) which would be after my AVR meaning it would tear up the distances and perhaps not work at all for video syncing...
So again, I loved the BACCH set up at Axpona and I think I liked it better than my L800's but I like the L800's better in my room and they fit within the home theater set up vs the one uBACCH VST that I've tried.
I plan on giving BACCH another go because the immersion was better.
Does anyone know those whisper and counting tracks he uses for demo's? I can't find them and I want to test them out. Yosi Horikawa's songs "Fluid" and "Timbres" were a revelation on his set up.
Thanks
