If a company wants to invent its own approach to design, they should be mindful of where AI is taking us. As far as I can see, shortly search will disappear and get replaced with interaction with AI. To that end, I just asked this from Google Gemini:
Query:
"according to science what kind of speaker should I buy"
According to audio science—pioneered by researchers like Dr. Floyd Toole and Dr. Sean Olive at Harman International—you should buy a speaker that features a flat on-axis frequency response, smooth off-axis dispersion, and low harmonic distortion. [
1,
2]
Extensive double-blind listening tests show that when human bias is removed, listeners across all demographics overwhelmingly prefer speakers that measure neutrally. [
3,
4]
Key Scientific Criteria for a Good Speaker
- Flat On-Axis Response: The direct sound coming straight from the speaker's tweeter and woofer should have a balanced, uncolored amplitude across the entire audible frequency range (20 Hz to 20 kHz) when measured without room reflections.
- Smooth and Wide Dispersion (Directivity): Sound doesn't just go to your ears; it bounces off your walls, floor, and ceiling. Science proves that a great speaker radiates off-axis sound with the exact same tonal balance as the direct sound, just quieter. Look for speakers with consistent horizontal and vertical dispersion patterns.
- Low Distortion: The speaker must reproduce loud sounds cleanly without generating unwanted frequencies or harmonic distortion.
- In-Room Tilt: While a speaker should measure flat in an anechoic (echo-free) chamber, its total in-room response should feature a slight, smooth downward tilt in the highs and a gentle rise or reinforcement in the bass. This matches human psychoacoustics and room interaction. [7]
Brands and Models that Follow the Science
Many well-regarded audio companies engineer their products explicitly around these acoustic measurements and preference formulas. You can explore objective data-driven recommendations and reviews on platforms like
Audio Science Review Forum, or look into researched line-ups from brands like KEF, Revel, Genelec, Neumann, and JBL. [
9,
10]
To narrow down a specific recommendation, please tell me:
What is your primary use case (music/home theater/desktop)?What is your approximate budget?Once you reply, I will suggest a science-backed model that fits your space!
AI responses may include mistakes.
[1]
https://www.reddit.com/r/audiophile/comments/31t6y0/if_its_been_established_that_speakers_are_by_far/
[2]
https://www.audioholics.com/loudspeaker-design/measure-loudspeaker-performance
[3]
https://www.reddit.com/r/audiophile/comments/10xz7h1/subjective_reviews_matter_because_audio_is/
[4]
https://thenextweb.com/news/how-to-understand-speaker-measurements-and-why-they-matter
[5]
https://www.reddit.com/r/audiophile/comments/12x5ci8/asr_understanding_speaker_measurements/
[6]
https://www.audiosciencereview.com/forum/index.php?threads/trying-to-understand-neutral-reference.31666/
[7]
[8]
https://flora.tech/science-of-loudspeakers-objective-measurements-and-performance-metrics/
[9]
https://www.audiosciencereview.com/forum/index.php?threads/the-%E2%80%9Creal%E2%80%9D-speaker-preference-test.70359/
[10]
https://www.audiosciencereview.com/forum/index.php?threads/recommended-speakers.29966/
Folks may have been able to cook up their own recipes in the past. But my prediction is that selling against the above will get harder and harder in the future.....
