Analysis of Paper on Measurements of RCA Cables by Kunchur (Video)
And this bit on authority of said site that published the paper. Prompt: "is iosrjournals.org considered a predatory journal?" (predatory means you pay and you get published)
Yes. I would describe IOSR Journals, including IOSR-JECE, as a likely predatory publisher, or at minimum a journal with publication practices so weak that its peer-review label should carry little evidentiary weight.
The evidence is unusually direct:
  • The publisher, International Organization of Scientific Research (IOSR), appears on the archived original Beall list of potential predatory publishers. That list is not a legal or infallible verdict, but it is a meaningful independent warning flag. of Potential Predatory Journals and Publishers
  • IOSR-JECE currently promises acknowledgment within 24 hours, “acceptance notification” after three days, and publication on a predetermined monthly date—an implausibly fast process for substantive double-blind technical peer review. iosrjournals.org
  • Kunchur’s paper itself lists submission on December 20, 2021 and acceptance on December 31, 2021—11 days, spanning the Christmas/New Year period. www.iosrjournals.org
  • IOSR advertises journal “impact factors,” but the page does not identify them as Clarivate Journal Impact Factors or provide a credible, transparent metric source. iosrjournals.org
That does not prove every paper it publishes is false, or that this paper received no review. It does mean publication there is not independent validation of the paper’s technical quality. For this cable paper, the arguments and data need to stand entirely on their own; “peer reviewed” in IOSR-JECE adds very little confidence.
So one wonders why Kunchur, who has written extensive in his actual field of experience, would submit this paper to such low quality outfit. Answer should be obvios.
So, a question could be ... will information we find on the web in the future even be trustworthy at all ?
Hasnt been for for years. Google searches have been steering you to what you believe for a long time. IMHO the internet is responsible for the increase in fla-earthers and anti-vaccers. You can find "proof" of almost any conspiracy theory, no matter how whacked.
The major technical problem: frequency-dependent capacitance is not proof of nonlinearity​
The paper says that dielectric behavior means a cable “cannot be represented by a fixed transfer function” and introduces history-dependent convolution as evidence. iosrjournals.org
That is incorrect reasoning.
A linear time-invariant network is defined by its impulse response/convolution: it necessarily has output dependent on prior input history. Frequency-dependent capacitance, dielectric loss, dispersion, and dielectric absorption can all be represented by a fixed linear transfer function—typically a distributed RC model or a sum of RC branches.
To establish nonlinearity, the paper would need to show that the response changes with signal amplitude: e.g., measure intermodulation, harmonic distortion, or impulse/transfer response at several voltages with carefully controlled error. It does not do that. The 5 V pulse tests show that cables behave differently at RF; they do not show relevant nonlinear signal alteration at line level.
I do a lot of linear modelling with frequency-dependencies. If he really wrote that such effects are non-linear, then that is for sure a problem. Now, modelling them with standard components can be difficult, but at times doable: https://pubs.aip.org/asa/jasa/artic...oviscous-acoustics-in?redirectedFrom=fulltext
Oh I don't know. Many AI searches cite ASR these days for many propositions. I'm assuming by "google search" you mean AI. Cheers.
It knows your a fan of ASR so it steers you there. If you were an audiphool it would have sent you to The absolute sound etc.
I just tried this prompt in Gemini: assume no context do audio cables make a difference
Its answer:
For a competently made cable, no — audio cables do not make a meaningful difference in sound quality once basic engineering requirements are met.
With context it did give a much more detailed answer but message was the same. I think we have made significant progress on this front. Try the same prompt and let us know what it does.
Reactions: EJ3
