Analogue DSP + High Impedance Headphones
tamkaho
I have unbalanced hearing and am using the Qudelix 5k to EQ audio to my Hifiman and possibly other headphones to balance the left/right frequencies independently.
I measured that the Qudelix has around 40ms latency in USB mode. Since I play the digital piano, I'm now looking for a setup that'll do something similar but with analogue input.
Requirements:
- low latency (<15ms)
- lowest budget possible
- must not take up too much desk space.
It seems the t.track mini 4x4 will do the EQ but the specs sheet says Output Impedance <500 ohm. Does that mean I'll need two other headphone amps (one per channel) or 1 headphone amp that takes balance analogue inputs (not sure if there is one). Space is tight.
Recommendations anyone?
