Newman
- Joined
- Jan 6, 2017
- Messages
- 5,133
- Likes
- 7,276
But only since we gave up analogue tape recorders!Along the same lines, computers are the least reliable things we own
.. 'Oops :>)How can "micro timing" or phase be better on something with wow and flutter? Ever see a sine wave come off vinyl? Its timing/phase is anything but stable. This phase movement will often spread out your sound stage and he thinks this means more audio information.
You cant monitor off the tape while recording or you get an unaceptable delay for the musicians. Which reminds of another drawback of tape machines. The gap between erase head and record head can cause blips when punching in. The little bit of tape between those 2 heads dosnt get erased so its a mix of the old and new takes.I can think of ONE advantage to tape. On a 3-head machine the playback head is right-behind the record head and you can monitor what's just been recorded. It's not unusual with digital to find out the next day that something terrible happened. Along the same lines, computers are the least reliable things we own, especially if your computer isn't dedicated to audio & recording and it gets messed-with during the day. But, I'm NOT going back analog!!!
I'm drifting off-topic but there is a fun-joyful rock song from the analog days by Larry Norman called Let That Tape Keep Rolling
I've only had one desktop tower (I don't bother with laptops) fail in the last 30+ years, and that was due to a massive lightning strike right near by ?I can think of ONE advantage to tape. On a 3-head machine the playback head is right-behind the record head and you can monitor what's just been recorded. It's not unusual with digital to find out the next day that something terrible happened. Along the same lines, computers are the least reliable things we own, especially if your computer isn't dedicated to audio & recording and it gets messed-with during the day. But, I'm NOT going back analog!!!
With the advent of ai, photography is strongly devalued. It all becomes rather pointless.
As someone who admittedly is 100% totally ignorant of photography, and also somewhat of music, could someone explain in layman's terms how AI can "devalue" a quality photo or music recording project. You guys lost me there.Only in the same way all the other creative arts are - including music.
Let's not forget though that on a multitrack, 24 or more especially - monitoring for overdubs and punch in's, as well as later sessions - comes from the recording head.You cant monitor off the tape while recording or you get an unaceptable delay for the musicians. Which reminds of another drawback of tape machines. The gap between erase head and record head can cause blips when punching in. The little bit of tape between those 2 heads dosnt get erased so its a mix of the old and new takes.
TIA, Sal
These days you can sit in front of an AI and ask it to generate an image. Keep going at it until you get the image that you want. No photographer gets paid, so the value of the photographer goes down.
Please create a photo quality image of this person pulling a wheely on a powerful motorbike.
Maybe I wasnt clear, you cant monitor what your recording off the tape (your using the record head to record so you cant use it to monitor, so if theres a drop out or other tape problem you wont know it till playback. Theres always distance between the erase head and the record head. When your punching and you hit record the erase head starts to erase and the record head starts to record, the tape between the heads dosnt get erased but it gets recorded to. you get a jump in level for that small bit of tape and you can often hear it as a "blip". This used to happen even with Studer tape machines.Let's not forget though that on a multitrack, 24 or more especially - monitoring for overdubs and punch in's, as well as later sessions - comes from the recording head.
And no - on a good machine nothing blips when punching in. Even at 15 inches, that gap is shorter than you can hit the button... My experience.
Cheers.
That's pretty incredible !WARNING - AI Created image incoming...
Just by way of an example, I took @Sal1950's avatar image, gave it to chatgpt, and with the prompt:
Chat GPT created this (It took less time to create the image than it took to download it from ASR, and upload it to chat gpt):
Amusingly ChatGPT thinks you pull the same face whether playing guitar, or pulling wheelies.
Studio machines allowed monitoring off tape using the record head, a function Ampex called SelSync. Studer had their own version. This meant that there was no latency for musicians. The audio quality was worse than off the proper playback head, but quite good enough for monitoring for overdub purposes.You cant monitor off the tape while recording or you get an unaceptable delay for the musicians. Which reminds of another drawback of tape machines. The gap between erase head and record head can cause blips when punching in. The little bit of tape between those 2 heads dosnt get erased so its a mix of the old and new takes.
... What i get from the transcript is he is comparing a mature analog technology with a primitive digital technology.
Thats what I said, then I added stuff. Reread my post #71.Studio machines allowed monitoring off tape using the record head, a function Ampex called SelSync. Studer had their own version. This meant that there was no latency for musicians. The audio quality was worse than off the proper playback head, but quite good enough for monitoring for overdub purposes.
S
And it can do it with video also. There are many scams going around working on the principle that if the viewer sees a celebrity or financial expert endorsing an "investment opportunity" in a video - that it is real. Whereas it can easily be created by AI using a prompt not much more complex than the one I used above.That's pretty incredible !
It's getting scary today that nearly nothing you see may be real unless you view it actually happening.
It is no longer possible to believe what you see on any screen.
Opportunities for scams are now very much greater. They can easily create a video of people you trust.The history of fakes is very long. Predates digital by thousands of years.That said, yes, digital makes it much easier. I hesitate to attribute it to AI, because the tools were there before we started overusing the term AI.
Don't miss this movie if you have not seen it. Very topical and funny for all ages teen and above. A good family holiday break.Or, imagine getting a video from your offspring, or grandchild, distraught, saying they are in trouble in south America, and need you to send money now.
