- Thread Starter
- #21
I do use that word to include rendering of IIR not just FIR filtersNote that convolution isn’t ideal for video
and yes I will use a video player with adjustable delay to resolve lip-sync issues
If you do it for long enough, the cost of experiment might exceed the cost of solution. Under your conditions, I really have no advice to provide.As I stated, the testing / learning process is the primary goal, not any one resulting implementation.
My budget is $200 per month, with credit getting abused if it helps accelerate that process, or if I spot crazy good bargains I think unlikely to be available in future.
Incremental investments, nothing over say $700 at once
Thanks right up my alley.If you really want to learn I would recommend you download VituixCAD and the documentation
Which is fine, walking around the world is more expensive than a cruise holiday.If you do it for long enough, the cost of experiment might exceed the cost of solution.
It’s not either/or. You can use them in tandem.but did not realise also well suited for modeling crossovers between enclosures including 2- 3-way speakers.
Do you reco it over say RePhase +REW for filter creation?
Thank you for that advice. Being poor is just a momentum-limiting factor, just saving money is not a design goalWith a limited budget, focus on DSP only. There is plenty to discover on that alone.
Yes I'm not going to limit myself, it's just a preference.It’s not either/or. You can use them in tandem.
RePhase and VituixCAD are not FOSS, neither is the OS they run onRePhase runs in wine, though. Did not have much luck with VituixCAD.
If you really want to go down that rabbit hole, look at something like this:I very strongly desire to start with analog, even if that costs more long-term.
www.audiosciencereview.com
Do you mean two subs? Stereo?I have found that double-bass setups with EQ sound better than using an analog crossover.
I mean running the subs (with LPF only) and speakers directly from the output of the DAC instead of going to the subs and then to the speakers (through the crossover of the sub.) You have to apply a lot of subtractive EQ to the bass but I think it sounds better.Do you mean two subs? Stereo?
I plan for that, plus MBM couplers berween the deep trueSubs and my LS50s as mid+trouble.
So do you mean using separate filters on each box independently, as having no crossovers?
