Xonar D1 arrived today. It's amazing. Same level on analog audio as my onboard S/PDIF, very comparable audio quality (I noticed immediately), no noise (similar to digital). I've regained the 30dB I lost with el cheapo CMI8738 and I can leave the Z906 volume alone, centered as it always was. No more clicks or crackling.You're willing to have an old soundcard shipped all the way from an island in the middle of the Mediterranean Sea? 'kay, whatever...
amixer -c D1 set Master 123
Simple mixer control 'Master',0
Capabilities: pvolume pswitch pswitch-joined
Playback channels: Front Left - Front Right - Rear Left - Rear Right - Front Center - Woofer - Side Left - Side Right
Limits: Playback 67 - 127
Mono:
Front Left: Playback 123 [93%] [-4.00dB] [on]
Front Right: Playback 123 [93%] [-4.00dB] [on]
Rear Left: Playback 123 [93%] [-4.00dB] [on]
Rear Right: Playback 123 [93%] [-4.00dB] [on]
Front Center: Playback 123 [93%] [-4.00dB] [on]
Woofer: Playback 123 [93%] [-4.00dB] [on]
Side Left: Playback 123 [93%] [-4.00dB] [on]
Side Right: Playback 123 [93%] [-4.00dB] [on]
What about the TV or any other devices connected to the AVR. Any of those grounded - in any way at all.Not grounded (2 prongs AC plug).
TOSLINKWhat about the TV or any other devices connected to the AVR. Any of those grounded - in any way at all.
None of that connectedOr do you have a loop in the interconnect (eg audio to AVR (RCA), Video to AVR (HDMI), or Video to TV with video also from AVR to TV.
I know. Very well aware of the potential issue.All of these can cause a ground loop that has nothing to do with mains ground.
The sole ground path to the AVR is via the shileded audio cables to the PCAs a test it would be worth disconnecting everything from the AVR, except speakers, and a single stereo audio from the PC.
No, it's completely gone the minute I plugged the new card in. Thanks for your assistance.Still get crackling?
Note to self - never reply until reading complete threadNo, it's completely gone the minute I plugged the new card in. Thanks for your assistance.
I followed your suggestion and set everything to SE32LE on linux; Win config is yet to be redone. Dual boot system.Very good. Did you try raising the sample bitwidth from 16? IMO both audio devices should support 24 or 32bits, then no need to drop information by truncating to 16 bits. Most likely inaudible, of course.
3: `Multichannel' Analog audio output on device Xonar D1
-hardware address: hw:1,0 (or hw:D1,0)
-formats: S16_LE, S32_LE
-usb audio class: (n/a)
-streamfile: (n/a)
-character device: /dev/snd/pcmC1D0p
-monitor file: /proc/asound/card1/pcm0p/sub0/hw_params
Pardon me if those are stupid questions but I'm really wondering as I never tried more resolution than 16 bits and more bandwidth than 48kHz.Very good. Did you try raising the sample bitwidth from 16? IMO both audio devices should support 24 or 32bits, then no need to drop information by truncating to 16 bits. Most likely inaudible, of course.
E:\Program Files\camilla\dsp>listdevices.exe
Available hosts:
[Wasapi]
WASAPI
Default Input Device:
Ok("Line 1 (Virtual Audio Cable)")
Default Output Device:
Devices:
Device: "Speakers (ASUS Xonar D1 Audio Device)"
Capture
Playback
Default output stream config:
channels: 6, samplerate: 48000, format: FLOAT32LE
All supported output stream configs:
channels: 6, samplerate min: 48000 max: 48000, format: FLOAT32LE
Why should increasing bitwidth raise latency? I do not see any technical reason.On linux I tried to set the playback device format (audio card via pipewire) to 32 bits but the increased latency is too important for videos: audio and video are out of sync just enough to be distracting, in the bad sense. Back to 16 bits fixed the problem. There is latency too but it's supportable. For music, there is no noticeable audible difference anyway.
If that binary comes from https://github.com/HEnquist/cpal-listdevices/tree/master , it uses shared-mode access only and the soundcard parameters listed are irrelevant to the exclusive mode access. It's hinted already by the float32 format which almost no hardware device supports natively.A final note on listdevices.exe. It seems to only report the sample rate selected in Sound/playback instead of listing the card capabilities, ignores the selected bitrate and reports FLOAT32LE, but has the number of channels correct. It's great to fetch the proper devices names.
I have near zero knowledge on digital audio technicalities. It's only a constatation, an undenyable fact.Why should increasing bitwidth raise latency? I do not see any technical reason.
Input #0, mpegts, from '/mnt/linux486/mythtv/1111_20240930230100.ts':
Duration: 00:28:59.56, start: 10775.128589, bitrate: 18241 kb/s
Program 1
Stream #0:0[0x31]: Video: mpeg2video (Main) ([2][0][0][0] / 0x0002), yuv420p(tv, bt709, progressive), 1280x720 [SAR 1:1 DAR 16:9], Closed Captions, 59.94 fps, 59.94 tbr, 90k tbn
Side data:
cpb: bitrate max/min/avg: 80000000/0/0 buffer size: 9781248 vbv_delay: N/A
Stream #0:1[0x34](fre): Audio: ac3 (AC-3 / 0x332D4341), 48000 Hz, 5.1(side), fltp, 384 kb/s (clean effects)
Stream #0:2[0x35](frm): Audio: ac3 (AC-3 / 0x332D4341), 48000 Hz, stereo, fltp, 192 kb/s (visual impaired) (descriptions)
Why pipewire when using CDSP? I am afraid I do not understand.
$ diff -ubB vlcrc.old vlcrc
--- vlcrc.old 2024-10-22 22:02:47.146951000 -0400
+++ vlcrc 2024-10-22 22:19:31.850532200 -0400
@@ -381,22 +381,22 @@
#scene-format=png
# Image width (integer)
-scene-width=320
+#scene-width=-1
# Image height (integer)
-scene-height=240
+#scene-height=-1
# Filename prefix (string)
#scene-prefix=scene
# Directory path prefix (string)
-scene-path=e:\temp\wintmp
+#scene-path=
# Always write to the same file (boolean)
#scene-replace=0
# Recording ratio (integer)
-scene-ratio=15
+#scene-ratio=50
[rotate] # Rotate video filter
@@ -548,10 +548,10 @@
[croppadd] # Video cropping filter
# Pixels to crop from top (integer)
-croppadd-croptop=33
+#croppadd-croptop=0
# Pixels to crop from bottom (integer)
-croppadd-cropbottom=33
+#croppadd-cropbottom=0
# Pixels to crop from left (integer)
#croppadd-cropleft=0
@@ -1574,7 +1574,7 @@
#file-logging=0
# Log filename (string)
-logfile=e:\temp\vlc.log
+#logfile=
# Log format (string)
#logmode=text
@@ -1645,7 +1645,7 @@
#qt-fs-controller=1
# Save the recently played items in the menu (boolean)
-qt-recentplay=0
+#qt-recentplay=1
# List of words separated by | to filter (string)
#qt-recentplay-filter=
@@ -2289,10 +2289,10 @@
#sout-x264-stats=x264_2pass.log
# Default preset setting used (string)
-#sout-x264-preset=
+sout-x264-preset=ultrafast
# Default tune setting used (string)
-#sout-x264-tune=
+sout-x264-tune=film
# x264 advanced options (string)
#sout-x264-options=
@@ -2622,7 +2622,7 @@
[schroedinger] # Dirac video decoder using libschroedinger
# Rate control method (string)
-sout-schro-rate-control=constant_noise_threshold
+#sout-schro-rate-control=
# Constant quality factor (float)
#sout-schro-quality=-1.000000
@@ -2640,7 +2640,7 @@
#sout-schro-min-bitrate=-1
# GOP structure (string)
-sout-schro-gop-structure=adaptive
+#sout-schro-gop-structure=
# GOP length (integer)
#sout-schro-gop-length=-1
@@ -2652,13 +2652,13 @@
#sout-schro-coding-mode=auto
# Motion Vector precision (string)
-sout-schro-mv-precision=1
+#sout-schro-mv-precision=
# Size of motion compensation blocks (string)
-sout-schro-motion-block-size=automatic
+#sout-schro-motion-block-size=
# Overlap of motion compensation blocks (string)
-sout-schro-motion-block-overlap=automatic
+#sout-schro-motion-block-overlap=
# Three component motion estimation (integer)
#sout-schro-me-combined=-1
@@ -2676,10 +2676,10 @@
#sout-schro-enable-phasecorr-me=-1
# Intra picture DWT filter (string)
-sout-schro-intra-wavelet=desl_dubuc_9_7
+#sout-schro-intra-wavelet=
# Inter picture DWT filter (string)
-sout-schro-inter-wavelet=desl_dubuc_9_7
+#sout-schro-inter-wavelet=
# Number of DWT iterations (integer)
#sout-schro-transform-depth=-1
@@ -2688,10 +2688,10 @@
#sout-schro-enable-multiquant=-1
# Size of code blocks in each subband (string)
-sout-schro-codeblock-size=automatic
+#sout-schro-codeblock-size=
# Prefilter (string)
-sout-schro-filtering=none
+#sout-schro-filtering=
# Amount of prefiltering (float)
#sout-schro-filter-value=-1.000000
@@ -2700,7 +2700,7 @@
#sout-schro-enable-scd=-1
# perceptual weighting method (string)
-sout-schro-perceptual-weighting=none
+#sout-schro-perceptual-weighting=
# perceptual distance (float)
#sout-schro-perceptual-distance=-1.000000
@@ -2715,7 +2715,7 @@
#sout-schro-vert-slices=-1
# Force Profile (string)
-sout-schro-force-profile=auto
+#sout-schro-force-profile=
[qsv] # Intel QuickSync Video encoder for MPEG4-Part10/MPEG2 (aka H.264/H.262)
@@ -3013,10 +3013,10 @@
[waveout] # WaveOut audio output
# Select Audio Device (string)
-waveout-audio-device=Speakers (Realtek AC'97 Audio) ($1,$64)
+waveout-audio-device=Line 1 (Virtual Audio Cable) ($1,$64)
# Audio volume (float)
-#waveout-volume=1.000000
+waveout-volume=0.824983
# Use float32 output (boolean)
#waveout-float32=1
@@ -3041,16 +3041,16 @@
[directsound] # DirectX audio output
# Output device (string)
-directx-audio-device=Primary Sound Driver
+#directx-audio-device=
#directx-audio-float32=1
# Speaker configuration (string)
-directx-audio-speaker=5.1
+#directx-audio-speaker=Windows default
-directx-volume=1.100000
+#directx-volume=1.000000
[amem] # Audio memory output
@@ -3271,7 +3271,7 @@
#equalizer-vlcfreqs=1
# Global gain (float)
-equalizer-preamp=0.000000
+#equalizer-preamp=12.000000
[compressor] # Dynamic range compressor
@@ -3279,22 +3279,22 @@
#compressor-rms-peak=0.200000
# Attack time (float)
-compressor-attack=1.400000
+#compressor-attack=25.000000
# Release time (float)
-compressor-release=1.900000
+#compressor-release=100.000000
# Threshold level (float)
-compressor-threshold=0.000000
+#compressor-threshold=-11.000000
# Ratio (float)
-compressor-ratio=1.000000
+#compressor-ratio=4.000000
# Knee radius (float)
-compressor-knee=1.000000
+#compressor-knee=5.000000
# Makeup gain (float)
-compressor-makeup-gain=0.000000
+#compressor-makeup-gain=7.000000
[chorus_flanger] # Sound Delay
@@ -4056,7 +4056,7 @@
#volume-save=1
# Force S/PDIF support (boolean)
-spdif=1
+#spdif=0
# Force detection of Dolby Surround (integer)
#force-dolby-surround=0
@@ -4083,7 +4083,7 @@
#audio-time-stretch=1
# Audio output module (string)
-aout=aout_directx
+aout=waveout
# Media role (string)
#role=video
@@ -4149,7 +4149,7 @@
#mouse-hide-timeout=1000
# Video snapshot directory (or filename) (string)
-snapshot-path=e:\temp
+#snapshot-path=
# Video snapshot file prefix (string)
#snapshot-prefix=vlcsnap-
@@ -4392,7 +4392,7 @@
#meta-url=
# File caching (ms) (integer)
-file-caching=10000
+#file-caching=1000
# Live capture caching (ms) (integer)
#live-caching=300
@@ -4401,10 +4401,10 @@
#disc-caching=300
# Network caching (ms) (integer)
-network-caching=30000
+#network-caching=1000
# Clock reference average counter (integer)
-cr-average=4000
+#cr-average=40
# Clock synchronisation (integer)
#clock-synchro=-1
@@ -4413,7 +4413,7 @@
#clock-jitter=5000
# Network synchronisation (boolean)
-network-synchronisation=1
+#network-synchronisation=0
# Record directory (string)
#input-record-path=
@@ -4527,7 +4527,7 @@
#repeat=0
# Play and exit (boolean)
-play-and-exit=1
+#play-and-exit=0
# Play and stop (boolean)
#play-and-stop=0
@@ -4545,7 +4545,7 @@
#playlist-cork=1
# Allow only one running instance (boolean)
-one-instance=1
+#one-instance=0
# Use only one instance when started from file manager (boolean)
#one-instance-when-started-from-file=1
@@ -4569,7 +4569,7 @@
#preparse-timeout=5000
# Allow metadata network access (boolean)
-#metadata-network-access=0
+metadata-network-access=1
# Subdirectory behavior (string)
#recursive=collapse
@@ -5295,7 +5295,7 @@
#bookmark3=
# Playlist bookmark 4 (string)
-bookmark4=file://gateway/mythtv/mp4/Les_Surhumains_-_Untitled_-_12.05.20.mp4
+#bookmark4=
# Playlist bookmark 5 (string)
#bookmark5=
Well, then something is incorrectly setup in your chain. Audio is processed in blocks, and the block size in samples determines the latency. Only some very CPU-intensive task could increase the latency (buffers + some CPU processing) but that would have to be quite a large load to be noticeable.I have near zero knowledge on digital audio technicalities. It's only a constatation, an undenyable fact.
Why not simply disable interface suspend?Analog audio crackling filter project.
The problem is caused by too high 'high quality' resampling settings, most likely. I don't want to read the whole thread to simply find out the answer, but OP should switch from whatever he's using to pipewire.Well, then something is incorrectly setup in your chain. Audio is processed in blocks, and the block size in samples determines the latency. Only some very CPU-intensive task could increase the latency (buffers + some CPU processing) but that would have to be quite a large load to be noticeable.
Re your VLC config - compressor setup? different volume settings?
I don't see anything obvious. Latency is 17 msec for this video. Maybe it's because it's 60 fps. Most of my material is 24-30 fps.Well, then something is incorrectly setup in your chain. Audio is processed in blocks, and the block size in samples determines the latency. Only some very CPU-intensive task could increase the latency (buffers + some CPU processing) but that would have to be quite a large load to be noticeable.
2024-10-23 12:03:37.689 T:45 debug <general>: CActiveAESink::OpenSink - trying to open device PIPEWIRE:alsa-sink
2024-10-23 12:03:37.689 T:45 debug <general>: CPipewireStream::StateChanged - stream state changed unconnected -> connecting
2024-10-23 12:03:37.690 T:270 debug <general>: ScanForExternalSubtitles: END (total time: 4 ms)
2024-10-23 12:03:37.690 T:270 debug <general>: LoadItemLookup: trying to extract filestream details from video file /mnt/linux486/mythtv/1151_20230121040400.ts
2024-10-23 12:03:37.692 T:45 debug <general>: CAESinkPipewire::Initialize - rate: 48000
2024-10-23 12:03:37.692 T:45 debug <general>: CAESinkPipewire::Initialize - channels: 6
2024-10-23 12:03:37.692 T:45 debug <general>: CAESinkPipewire::Initialize - format: f32
2024-10-23 12:03:37.692 T:45 debug <general>: CAESinkPipewire::Initialize - samplesize: 4
2024-10-23 12:03:37.692 T:45 debug <general>: CAESinkPipewire::Initialize - framesize: 24
2024-10-23 12:03:37.692 T:45 debug <general>: CAESinkPipewire::Initialize - latency: 2400/48000 (0.017s)
2024-10-23 12:03:37.692 T:45 debug <general>: CAESinkPipewire::Initialize - waiting
2024-10-23 12:03:37.692 T:270 debug <general>: ffmpeg[0x561d899eed80]: [mpegts] Could not detect TS packet size, defaulting to non-FEC/DVHS
2024-10-23 12:03:37.692 T:270 debug <general>: Open - avformat_find_stream_info starting
2024-10-23 12:03:37.692 T:270 debug <general>: Open - av_find_stream_info finished
2024-10-23 12:03:37.692 T:270 debug <general>: ScanForExternalSubtitles: Searching for subtitles...
2024-10-23 12:03:37.692 T:12 debug <general>: CPipewireStream::StateChanged - stream state changed connecting -> paused
2024-10-23 12:03:37.693 T:45 debug <general>: CAESinkPipewire::Initialize - initialized
2024-10-23 12:03:37.693 T:45 debug <general>: CActiveAESink::OpenSink - PIPEWIRE Initialized:
2024-10-23 12:03:37.693 T:45 debug <general>: Output Device : Alsa Loopback
2024-10-23 12:03:37.693 T:45 debug <general>: Sample Rate : 48000
2024-10-23 12:03:37.693 T:45 debug <general>: Sample Format : AE_FMT_FLOAT
2024-10-23 12:03:37.693 T:45 debug <general>: Channel Count : 6
2024-10-23 12:03:37.693 T:45 debug <general>: Channel Layout: FL, FR, FC, LFE, SL, SR
2024-10-23 12:03:37.693 T:45 debug <general>: Frames : 2400
2024-10-23 12:03:37.693 T:45 debug <general>: Frame Size : 24
devices:
adjust_period: 30
capture:
channels: 6
device: Line 1 (Virtual Audio Cable)
exclusive: true
format: S24LE3
labels:
- FL
- FR
- FC
- LFE
- RL
- RR
loopback: null
type: Wasapi
capture_samplerate: null
chunksize: 2048
enable_rate_adjust: true
multithreaded: null
playback:
channels: 6
device: Speakers (ASUS Xonar D1 Audio Device)
exclusive: true
format: S24LE3
type: Wasapi
Loopback capture in wasapi means you capture sound from a playback device. To use it with CamillaDSP, you would set a second (unused) sound card as the default device, and let CamillaDSP capture from that one in loopback mode. And then you configure CamillaDSP to play the processed sound on the device you actually want to listen to. You need a second sound card to make use of it.In https://github.com/HEnquist/camilladsp/blob/master/backend_wasapi.md it is mentioned that you can use a loopback. Does anyone have a real example of this, because I don't understand anything about it. I don't have a second sound card.
Thanks Henrik,Loopback capture in wasapi means you capture sound from a playback device. To use it with CamillaDSP, you would set a second (unused) sound card as the default device, and let CamillaDSP capture from that one in loopback mode. And then you configure CamillaDSP to play the processed sound on the device you actually want to listen to. You need a second sound card to make use of it.
What do you mean by "didn't pick it up"?But CDSP didn't pick it up as capture device.
i.e. absolutely nothing happened. no activity in CDSP. like it wan't listening at all. all meters halted in the gui. nothing in the log.What do you mean by "didn't pick it up"?
From: https://learn.microsoft.com/en-us/windows/win32/coreaudio/loopback-recordingIn versions of Windows prior to Windows 10 1703, pull-mode capture client does not receive any events when a stream is initialized with event-driven buffering and is loopback-enabled. To work around this, initialize a render stream in event-driven mode. Each time the client receives an event for the render stream, it must signal the capture client to run the capture thread that reads the next set of samples from the capture endpoint buffer. In Windows 10 versions 1703 and higher, event-driven loopback clients are supported, and no longer need the workaround involving the render stream.
