Count Arthur
- Joined
- Jan 10, 2020
- Messages
- 2,230
- Likes
- 5,004
"10 uSec -> bw 100MHz" ..oops!
Messala said it best, It goes on Juda, it goes on...
You got it thoughAnd the "Obscure reference to a 1950s movie" award goes to....
The whole thing about mqa is based upon the assumption that more bits and higher sample-rates than CD will result in better audio. Well, 24 bits will have lover noise floor than 16 bits, and higher dample-rates will make construction nd implementation of filters easier. Maybe. But how many of you think noise floor is a problem when listening to CD music, and what is the point sending higher than 20 khz signals into the speakers? Do we really need better than CD at all?
The whole thing about mqa is based upon the assumption that more bits and higher sample-rates than CD will result in better audio. Well, 24 bits will have lover noise floor than 16 bits, and higher sample-rates will make construction and implementation of filters easier. Maybe. But how many of you think noise floor is a problem when listening to CD music, and what is the point sending higher than 20 khz signals into the speakers? Do we really need better than CD at all?
Yes. But are they made from the same master? I think the best test is to downsample some high-res files to 16/44 and compare. Blind of course.MQA got me started in higher res audio. I purchased a DAC that was MQA enabled and got a taste then purchased a much better DAC that was also MQA enabled then started downloading high res music files after auditioning them on Tidal. I can attest that non MQA downloads sound better than the same MQA Tidal tracks. So now if I find something I like on Tidal I’ll purchase the non MQA file from hdtracks or some of the other sites that offer high res audio. I have several duplicates now of 16 bit red book cds and 24 bit 92-356.2khz files and almost always the higher res files sound better. There are a few duds though.
It doesn’t matter to me if they are the same master or not. If it sounds better I don’t care how they got there. It’s all about the music to me. Some high res absolutely doesn’t sound as good as the original cds.Yes. But are they made from the same master? I think the best test is to downsample some high-res files to 16/44 and compare. Blind of course.
It plays a very big role in relation to the question I asked, ie whether in the light of MQA there is a need for high-resolution audio files at all.It doesn’t matter to me if they are the same master or not. If it sounds better I don’t care how they got there. It’s all about the music to me. Some high res absolutely doesn’t sound as good as the original cds.
