An Enticing Marketing Story, Theory Without Measurement?
UliBru
The scale is a bit difficult too se the intertime difference p-p, is it possible to give an estimate?
The time scale is in seconds. But IMO it is senseless to discuss about a p-p time as the resulting sum does not show up an intertime reference. Both drivers start at the same time but there is a delay to achieve the result.
The pulse responses look like this
Thomas_A
Sweden
So there is around 1ms p-p intertime difference in this time-aligned response? It surely must be differences depending on the woofers covering range. If you measure the start of drivers action it will be zero. What I am getting at is that you need to compare relative differences between the drivers when comparing step response of time-aligned vs trad crossover. Or look at the impulse response. If there is a 2ms p-p difference between tweeter and woofer in a traditional crossover you need to compare that to the p-p difference between the same setup tim-aligned. The difference between these two numbers will be the actusl delay.
UliBru
Once again: it does not make sense to discuss the p-p difference with individual driver measurements. If there are p-p differences in the total measurements this may be worth to discuss. In the given example of time-alignment there is no p-p difference in the sum.
BTW this kind of time-alignment is not achievable by just adding a delay to an individual driver or by e.g. shifting the tweeter forward/backward or by tilting the speaker.
Thomas_A
Sweden
If you say so regarding that there is no point in relating the p-p it is so also for a traditional crossover. If would instead measure the start of the response you can also look at the impulse response. Easier.
krabapple
I've never found that helpful, personally. You cannot EQ a loudspeaker to fix problems that are not created by it, in this case, overly lively or dead rooms. A good loudspeaker, in a good room.. We listen 'through' rooms, but we can't ignore it either.
You can in once case, if I understand Dr. Toole correctly: when the recording itself is imbalanced. Then broadband tone control could help. But that's on a recording-by-recording basis, not something you'd leave 'on' all the time. And again, best predicated on having well-behaved loudspeakers, and room issues tamed, first.
TimVG
Sure, tone controls or a tilt function can be handy depending on what’s playing. Best to start of with a neutral baseline though.
