There's isn't much point in continuing this. You're overlooking and throwing away a lot of acoustic researchers and well know psychoacoustics and holding on to only one that primarily talks about preferences. I'm talking about accuracy and as mentioned before when it comes to preferences a lot aspect are in play and it becomes difficult. With accuracy it's a lot easier.
What? You have not references one research paper or controlled testing to back anything you have posted. So please don't keep saying pscychoustics this and that. You need to provide actual back up.
And let me get this straight: you are saying if I blind test two rooms and one is preferred over the other, I am supposed to think it is less accurate and I should go with the one I like less? What logic is that?
Humans have an internal fidelity compass when it comes to sound reproduction. We know if bass is too high or it distorts without a reference. Likewise, we know what sound we like because it seems more real to us. Your assertion that I should go by what makes sense to one's intuition about sound and reflections has been debunked in countless research papers and studies. It is all documented in Dr. Toole's book in exhaustic level including some 270 references. This is not some idle forum post you can brush aside with that starting comment. It is your position that needs validation, not the other way around.
You talk about psychoacoustics. Well, there is no better textbook on that than Zwicker and Fastl. And this is what Zwicker had to say on topic of reflections in his peer reviewed paper showing the improvement of speech in the presence of reflections:
”Using the loudness exceeded in 10% of the time as an indication of the perceived loudness, it can be expected that the speech is 1.2 times louder in the room with 0.6-s reverberation time and about two times louder in the room with 2.5-s reverberation compared with the loudness produced in the free-field condition. This increment in loudness is often very helpful for the intelligibility of speech in rooms as long as the reverberation time does not produce temporal masking, which reduces the audibility of faint consonants appearing in sequence to loud vowels.”
Temporal masking is the reason we don't want the room to be too live if we care about speech intelligibility.
Here is the introduction section of the Journal of ASA paper,
”The influence of spectral characteristics of early reflections on speech intelligibility,” by Arweile and Buchholz, dated 2011, on the same point:
”Early reflections (ERs) of a sound in a given environment are characterized by arriving at the listener’s ears shortly (approximately within 50 ms) after the direct sound (DS). They are integrated with the DS in the auditory system, i.e., within a certain time window their energy is added to the energy of the DS. With regards to speech intelligibility the DS and the ERs form the useful part of the speech signal, whereas late reflections are considered detrimental for speech intelligibility. Thus, the effective level of a speech signal depends on the energy of the DS and the energy of the ERs at the listener’s ears. ER [early reflection] energy increases the effective speech level and has been demonstrated to improve speech intelligibility (Lochner and Burger, 1964; Na´beˇlek and Robinette, 1978; Soulodre et al., 1989; Parizet and Polack, 1992; Bradley et al., 2003).”
Isn't this accuracy? Hearing and understanding words?
Again, all of this research is included in Dr. Toole's book with a simpler style that is understandable by people outside of the industry/research. Please read and understand it all before jumping into this industry.
