Amps with streaming and room correction list,site ?
gasolin75
Denmark
I was trying to google if there was somewhere, where there was a big list of amps with streaming + (very important, to avoid a streamer like a wiim plus pro) room correction
I didn't find any
Does any know of a list or site with amps that has streaming and room correction ?
Pricrunner as my local site for searching thru hifi and pc offers, don't have that option to search for + i have to read thru the amps description or google it to find if it has room correction.
Streaming is much more easy to see if an amp has, it's from a wiim amp up to 2000 euros so not high end av receiver or 20-30-40kg high end stereo amps with 200 watt pr channel or more in 8 ohm
I don't follow. The WiiM Pro Plus has room correction.
Anyway, here are some Amps with streaming and room correction:
-WiiM Amp
-WiiM Amp Pro
-WiiM Amp Ultra
-Eversolo Play
-NAD M10
-Denon Home Amp
-Marantz Model M1
Reactions: MAB
amps not streamer
Technics SU-GX700
yamaha r-n800a and r-n1000a
amps not streamer
Technics SU-GX700
Here is the title of the thread:
@staticV3 gave you a list of amps with streaming and room correction, just like you asked:
I would add the MiniDSP SHD:
There are a ton of ProSound solutions.
Perhaps clarify what you are looking for, otherwise we are talking past each other.
I just wanna see what not crazy expensive amps there is with streaming + room correction because if i later wanna upgrade to better speaker i need,want a better amp, streaming and room corrections is what i want
I don't mind yamaha but i like wiim amp more
If i use vibelink + a wiim pro plus or ultra streamer, i think i have to use the streamer for my 4 sources or else i won't be able to use them with room correction, max is one analog unit like my turntable and one digital, my pc, then my cdplayer and tape deck has to go in the amp (no room correction) or use a source selector (no gain control for each source)
Despite how good wiim amp pro and above amp and amp/streamer combos are, 4 sources can't be all connected to one unit that does room correction for all 4 sources
OK, those three WiiM that staticV3 mentioned are amps that have built-in streamers and DSP for correction. They're not crazy expensive and have everything you asked for. :)
How about the Lyngdorf TDAI-1120? It is a little over $2,000 here in the US. It is made in Denmark so it may be offered at a better price there. 120wpc, streaming, and RoomPerfect.
Reactions: MAB
Lyngdorf TDAI-1120 is way to expensive, it's 2000 euros
Nad 700v2 is also very expensive + dirac live (full bandwith) is sooooo expensive 1606 euros
preout from an amp to a streamer and back to the amp + all 4 sources connected to the amp, i cant seem to find something, atleast not with wiim
wiim vibelink + ultra streamer is around 800 euros but cant see how it would do room correction from all 4 sources, the streamer don't support 4 sources and i have to use the optical in on the i can't use for my pc or cdplayer
The WiiM Ultra supports 6 sources:
-Line
-Phono
-Toslink
-ARC
-BT
-Network
And you can add two more Toslink for cheap, for a total of 8 sources:
All 8 sources will be room corrected.
It won't support MY 4 source with all inputs on the amp or streamer for samme adjustments for all sources, unless i use a source selctor which i have (no gain control for each source analog has to be unify for all sources connected to that)
2 or 3 analog in + 1 or 2 digital in (cd can be use analog or digital in toslink) pc can be both but for ease of use i like usb
Streaming and bt does most streaming amps support ;-)
Meaning when i only have one analog in i can't make a custom eq or if possible make a subsonic filter for my turntable, = i have to use an externat riaa if i want subsonic filter
wiim amp ultra is not an option i have a wiim amp pro
