oneanother
- Joined
- Jan 15, 2024
- Messages
- 19
- Likes
- 1
- Thread Starter
- #21
Thank you. AUDIOPHONICS HPA-DM750ET Power Amplifier Purifi 1ET9040BA looks good. But as @MBO wrote about Purifi 7040, if these were not enought, will be the Purifi 1ET9040BA good?Regarding the preamp. It depends on how many inputs you want. What sources do you have?
If you only use streaming and already have, as you say, a good DAC, then you really only need a streamer. Does your DAC have a volume control?
Purifi 1ET9040BA. Build yourself?:
PURIFI EVAL4 Mono 1ET9040BA Amplifier Evaluation Kit 750W 4 Ohm
Purifi's EVAL4 is an evaluation kit comprising a 1ET9040BA mono amplifier module and a FE04 mono input card. It is perfectly suited to integration in DIY audio projects.www.audiophonics.fr
or ready-made:
The Audiophonics HPA-DM750ET is a Class D power amplifier featuring dual mono architecture. Integrating two Purifi 1ET9040BA amplifier modules and two independent Hypex SMPS1200A180 power supply boards,www.audiophonics.fr
Buckeye Amps
Buckeye Amps utilizes the most advanced audio amplifier technologies available. Authorized seller for Hypex and Purifi Class D amplifiers. Based in the US. Free shipping and worldwide service!www.buckeyeamp.com
PURIFI 1ET9040BA Buckeye or Audiophonics
I would like to buy a PURIFI 1ET9040BA Monoblock for front speaker and I am confused between several companies because of the difference in gain amp between them I have a question about perfect match gain amp with storm audio ISP MK3 processor ? Also I do not know about the quality of these...www.audiosciencereview.com
Edit:
A streamer, any WiiM product? WiiM Pro together with your DAC for example. An advantage of WiiM is that it has PEQ, both manual and automatic (RoomFit)
Fixing the FR in the sub bass area is always necessary if you want to get good bass.![]()
Optimizing Your Audio Experience: A Comprehensive Guide to RoomFit™
TABLE OF CONTENTS Overview Benefits Room Correction vs. EQ Summary Preparations and Instructions Before Calibration During Calibration Step-by-Step Guide Troubleshooting and Tips Overview Room correction is a process that inv...faq.wiimhome.com
You can measure with your mobile phone's microphone together with WiiM but I recommend that you buy a Dayton Audio iMM-6C Calibrated USB-C Measurement Microphone for Apple/ Android for better results.
Dayton IMM-6 microphone setup and measurement
This is a reminder of the setup and measurement procedure of the Dayton Audio iMM-6 microphone used for WiiM Room Correction(RC). If RC supports IMM-6, this might be useful to someone. Please allow me to post in the request thread with the expectation of IMM-6 support. The IMM-6 series is...forum.wiimhome.com
In a diferrent setup, I am using now SMSL D6S with Topping LA70 as preamp, feeding Fosi ZA3 monoblocks for my Dynaudio Emit M30 and it is nice. D6S alone as an preamp was very thin sounding. Adding LA70 as an preamp makes a big improvement.
S I can use D6S with Topping LA70 as an preamp. I have also Chord 2Qute, Mojo2, but I use these for headphone setups. D6S has a balanced output which I want to use to not worrying about ground loop.
How about Topping B200? Will this work?I had a Purifi 7040 for my Canton Reference 5k speakers, and even that amplifier couldn't control them properly in the low frequencies. I'm currently experiencing a significant improvement with two Topping La90D amplifiers in mono mode.
