Yes and no.
In case A you have source>power amp>speaker.
In case B you have source>power amp>loudspeaker load>resistors to drop voltage>power amp>speaker.
That's an interesting way to do it. Do you know what they used for the load?
Yes and no.
I'll see if I can find the schematic. I don't know the speaker, but they made a simulated load that was very close to the real speaker they were using. It was rather demanding as I recall though not something crazy like some ESLs.That's an interesting way to do it. Do you know what they used for the load?
Very small frequency tilts over a frequency range are audible. I don't usually use the "appeal to authority" but it is specifically mentioned in Floyd Tooles book so I think I'm on good ground here.I have extremely high regard for @March Audio (which is no secret) and I'd be happy to use his amps. But... his support for that claim has not been very strong, and I think it's likely that this isn't right.
I'm not clear on what you are saying.It's the NC400 module thats .4dB down at 20kHZ, not really your amp, though, right? So assuming the NC400 was flat all the way up to 150kHz, your amp would measure flat that high too yeah?
I just tried + 0.5db @ 7KHz , also -0.5db @ 7KHz . Couldn't hear the difference to to save my life.0.5 to 0.6dB down
I'm all set.
Not sure what type of bats Toole used that could hear 0.5 db difference @20KHz , but I know I'm not one.
Its not a boost or cut at a specific frequency thats audible, its a tilt in frequency response - change over a range of frequencies. It will depend also on the spectral content of the music you are listening too and of course your hearing.I just tried + 0.5db @ 7KHz , also -0.5db @ 7KHz . Couldn't hear the difference to to save my life.
I'm all set.
Very small frequency tilts over a frequency range are audible. I don't usually use the "appeal to authority" but it is specifically mentioned in Floyd Tooles book so I think I'm on good ground here.![]()
Yes.are we talking about a tilt being audible where a shorter step deviation would be inaudible?
Thats the way I understand it yes.are we talking about a tilt being audible where a shorter step deviation would be inaudible?
Here is a clip of white noise (not representative of music but shown to demonstrate the point) with a section filtered to be 0.5dB down at 20kHz. Its plain as day. Interestingly I find the change to the filtered section when it starts is less noticeable than when it ends.
Fortuantely or unfortunately I don't do above 12250 , so when there is a party at 20KHz, I'm not invitedAgain I have to emphasise we are not talking massive differences here, but detectable yes.
I think its very unlikely.Could this be the (increasing) phase shift you are perceiving?
Since you mention a clearer experience through headphones.
from Dr Floyd Toole:
" It turns out that, within very generous tolerances, humans are insensitive to phase shifts. Under carefully contrived circumstances, special signals auditioned in anechoic conditions, or through headphones, people have heard slight differences. However, even these limited results have failed to provide clear evidence of a 'preference' for a lack of phase shift. When auditioned in real rooms, these differences disappear.. ."
(excerpt from https://www.audioholics.com/room-acoustics/human-hearing-phase-distortion-audibility-part-2)
I would also add that with errors at HF, white noise works even better.IMHO hearing such small differences works better with pink noise than with music.![]()
