"Noise output voltage" is that the absolute noise level , the usual specs are only relative "SNR ratio" .
Yes. I think it is measured at 0dB (max output) calibrated according to manufacturer specs.
One can easily detect 0.3% THD and -70dB crosstalk... if it comes from an amp chip like the inglorious TDA8950 (a pretty broken PWM design).... why? Because it is tons of higher harmonics only with a non-stable spectrum vs power... piano decay sound like digeridoo...The infamous $10,000 amp challenge parameters:
• <2% THD across 20Hz-10kHz
• Channel balance matching <0.5dB
• Crosstalk >30dB
I don't know most noise output voltage I've seen is at idle.
Well, I hope you do that when you already have extremely good speakers (i.e. with distorsion measurements available).Some of us are simply trying to construct the cleanest possible signal path for the elimination of doubts (and to minimize upgrade desires) within our own personal parameters and predilections.
You can guess what's our take. This kind of audiophile is by definition neurotic, or even psychotic, for those who "really hear something".I don't know guys, may be my ears are broken or those people are getting nuts.
Nobody claims all amps sound the same, there is always the qualification at least that they both have to be operating under clipping level.There is one test although not all the detail that you mention is there: https://www.audiosciencereview.com/...ts-did-show-amplifiers-to-sound-different.23/
When I was buying amp for my system I went for THX Ultra certified amp.
Most of the certified amps are multichannel and manufacturer has to pay for certification test even in the case when amp failed to get it.
It would be interesting to see one of those THX certified amps/AVRs tested here.
Richard Clark performed his test over 500 times with no winners. He stopped doing it after that.Nobody claims all amps sound the same, there is always the qualification at least that they both have to be operating under clipping level.
Richard Clark had the famous $10k challenge for anyone that could distinguish between two amps in blind ABX testing. (As far as I know, prize was never claimed, and he ran a lot of tests).
His caveats:
Amps had to be competently designed and in good working order.
The level had to be exactly matched
Frequency response had to be the same, if not he would EQ with a filter to match
Amps operated below their clipping power level
Speakers had to be regular dynamic drivers, not panel designs.
Within these constraints, users could bring any amps and speakers they desired to take his challenge test.
This is all quite sensible for this kind of test. He also never claimed all amps were the same. Just that for a given power level, things like price, features, esthetics, reliability should be the determining criteria when purchasing an amp.
The interesting thing is that his tests proved what he did not believe, and many people still don’t, was true.
The test run in this article is not that interesting, outside that it demonstrates amps have different clipping characteristics, that are audible to some degree.
What is interesting is that Benchmark has this whole “first watt” theory, that performance at low output levels is critical for superior audio performance.
On their site they have a discussion of this theory, and the results of an ABX test they claim easily showed that their AHB2 was distinguished from a decent competitor at a low power level.
However, they only disclose that this test was passed with a test tone! I would presume they attempted the same test with music. Since they don’t mention it, I infer that their amp was not distinguished from the competition in ABX listening tests with music.
If this is the case, they refute their own argument!
Weird.
https://benchmarkmedia.com/blogs/application_notes/power-amplifiers-the-importance-of-the-first-watt
Did you match levels carefully in these tests? Not by ear either, but with a meter.I currently have a Matrix Audio HPA-3B and 789. They are very close but the Matrix has slightly more punch in the bass and the mid range has more body. It's marginal but noticable ABX'ing them from the same DAC. The difference being is one is class A and the other is A/B.
I actually prefer the Matrix a little but love the 789 too. It's also worth noting I do have opa1656's in the Matrix and it already had two sparkos voltage regulators. I'm not sure what they do but supposedly the opa1656 has low distortion numbers and was recommended by a TI engineer.
Another thing I just noticed was the 789 is 6 watts @ 32 ohms and the matrix is 3.8 but at 300 and 600 ohms the matrix has double the power and then some.
At ASR I see peope trying to let the science of audio guide their knowledge, knowing that all human perception is, by nature, not fact, consistent or measurable.
So, we shouldn't let science 'guide' our knowledge?
