I own the nad c368 and am wondering if the differences you are hearing are also present with dirac switched off. That would be more comparable with what to expect from the nad c298 I suppose.
My rating was of course on hearing without DL correction
Welcome to the physical world, which does not only consist of querying a few specification values and therefore can only be part of the whole truth.
With DIRAC LIVE in operation, I have the following experience:
As soon as I want to improve my listening experience with DL, I get a lifeless and cloudy sound (even with my corrected problem area of 20-100Hz only). According to the DL manufacturer, there should be no deterioration! Interestingly, I am not alone with this experience, as you can read in other forums.
I am assuming that the reproduction potential of high-quality loudspeakers cannot be fully captured by measuring microphones (i used a UMIK-1 and the original supplied measuring microphone). The DIRAC LIVE corrected result sounds now like a mainstream loudspeaker which is unacceptable to my ears. Other users have improved their listening experience using speakers which do not sound like e.g. an Avantgarde Acoustic or a large B&W with suitable equipment.
And that could be the solution.
See below:
Earthworks FAQ - 02 / Technical
'Why do you make microphones that exceed 20kHz?'
Link:
Earthworks FAQ
With such a microphone (type M50, …), the happening in the room can really be captured correctly, i.e. deliver optimal data for the correction calculation.
I will do my next attempt with a UMIK-2 instead of my UMIK-1. An improvement should be audible here.
In the meantime i correct with a self-generated flat curve and adjust it with the help of rew. With this solution I don't get a lifeless and cloudy sound.
