RogersCompactMonitorFan
- Joined
- Mar 8, 2023
- Messages
- 22
- Likes
- 20
I feel this might have been covered before, but I can't find an appropriate post...
TLDR: I'd like to measure CD player+amplifier+speaker frequency response and distortion using a Tascam SD-card audio recorder as I don't have a Microphone. Is this do-able relatively easily?
I've got a couple of amplifiers from the 1970s. One of them sounds "warm" compared to my Aiyima A07 amplifier, and I'm curious to find out why (or indeed, IF - is this my imagination? So I'd like to do Audio Science.)
Related: I have an old Sony CD player from the 1990s which I think sounds a bit distorted, and again I thought it would be good to measure to see if this is the case or if I'm imagining things.
While I'm thinking about measuring I thought it would be interesting to add speakers (and room) and do a comparative measure - this would need a microphone.
My thoughts are:
- Generate audio frequency sweep files and burn them to a CD to play on the CD player (I might already have some on an audio test CD I think I downloaded and burned once).
- Build a potential divider and dummy speaker load (I have 2x 3 ohm wire wound resistors which should make a 6 ohm load) and connect 2 additional potential divider resistors such that the amplifier output can feed into a sound card or audio recorder.
- Step 3 = Process the recorded audio files to derive frequency response/distortion measurements.
I have a Tascam DR-07 Mk2 audio recorder. It doesn't have a calibrated frequency response that I know of, but I thought it likely to be "flat enough" for speaker/room tweak comparisons. This would save spending the money on an UMIK1/similar microphone. The recorder can be battery powered, so should be OK with a differential speaker output from the Class D Aiyima amplifier.
I'm assuming a calibrated microphone would give "accurate" room results, but if I only want relative measures I assume I don't need the calibration so much.
The Tascam specs https://tascam.jp/int/product/dr-07mk2/spec claim:
24bit/96kHz recording
Freq response: 20Hz to 40kHz +1dB/-3dB(Fs 96kHz, EXT IN to LINE OUT, JEITA)
Distortion: 0.05% or lower(Fs 44.1k/4k8/96kHz, EXT IN to LINE OUT, JEITA)
SNR: 92dB or higher(Fs 44.1k/48k/96kHz, EXT IN to LINE OUT, JEITA)
...which "looks probably good enough" for what I want. I'm assuming if I believe I can hear distortion it will be much more than 0.05%, and I'm sure it's likely such a thing has a pretty flat response on the line input.
It looks as though REW has the ability to generate frequency sweeps, but I'm unsure if it can work with a WAV file from an audio recorder.
I can solder up some resistors, but I think the bit I'm missing is "software that runs on MacOS/Linux which takes a .WAV file and outputs statistics/charts"
It looks as though Audacity might have a distortion plugin - https://forum.audacityteam.org/t/distortion-analyzer/8218/21 - but I don't know if it works well in this application or not.
Has anyone else done something similar and can point to some tips?
Many thanks.
My thoughts are:
Many thanks.
