[Regarding 70's amps designed for "peak Power"] ...simply ran out of steam when really pushed and things got ugly, fast.
This goes beyond the discussion of the Crown XLS2502 power amp, so I started a generic thread on the topic.
I would like to hear from some of our resident technical experts about genres of music and variations in amplifier power requirements. I'm not going to get into the "how much power is needed for tweeters" argument. However, in my many years of playing with audio, I have never bothered to learn to read and fully comprehend waterfall and other complex speaker test graphs, but I assume that some of them show power and current vs. SPL and frequency. ("Speaker graphs and how to read them" would be a great topic for a member with expertise in the area to post a tutorial.) '
My lifetime of listening to music - acoustic and amplified, live and recorded - leads me to believe that the sustained "music power" levels of amplified instrument music, up to including sub-genres of heavy metal and bass-thumping pop styles, would be a poorer application for amps that are designed to provide additional "clean" peak power for actual short-term peaks. Acoustic music (vocals and acoustic instruments) and recordings with a high dynamic range would seem to be a better application for "music power" reserve type designs. Bi-amping also makes sense to me in some situations, and I consider subwoofers - active or passive - to be a variation of bi-amping.
Intuitively, it seems to me that a fraction of a second of higher power demand wouldn't be much of a problem, but once you get up to a second or more, one would really need "sustained" high power capability rather than a reserve. But this is complicated - and eliminated by simply using a very powerful low distortion amplifier that is less likely to blow your speakers than a weaker amp driven into massive distortion. My Classé 70wpc class AB with its inaudible (from a couple of feet away) mechanical power transformer hum is perfect for my needs, and drives my little and very bass-limited Paradigm Atom v6 bookshelf speakers to very loud levels in a small room.
Another factor regarding amplifier performance that you may remember from previous conversations here, is that no-reserve amps that supposedly "track" demand and provide power as needed - like the old Carver Cubes and Bob Carver's other "Magnetic Field" power amps - perform miserably under sustained loads, and indeed, mine went into thermal shutdown during a party at my house while driving a pair of ADS-L810 speakers.
Bottom line for semi-technical audiophiles, as long as there is power for sufficient bass demands of the music one listens to, it seems to me that a modestly powered amp with good "reserve power" make sense only for acoustic and other "low-power" music.
