@DonH56 Have you ever had experience with electrostatic speakers and SS amplifiers? I haven't owned any so can't really comment. And no, there's none in my storeroom.
There's always been a lot of discussion regrading amplifier output impedance and the capacitive nature of stats at HF. I'm expecting a stability issue if anything or increased THD at high frequencies/levels.
Yah, a fair amount. Always expected I would own a pair of ESLs but never did, though I have serviced, sold, and auditioned many in my own and others' systems.
As you know, the ESL panel is basically a big capacitor, and can look like several uF at HF. The actual load to the amp is not always capacitive, since it is usually transformer-coupled, but the impedance is very, very low (often 1 ohm or less at 20 kHz) and often with a large phase angle. So, your gut is right, distortion tends to go through the roof and stability can be a major problem. The saving grace for many amps (and speakers) is that the HF content is low enough in amplitude that they can handle it.
I have seen one ARC tube amp smoke the output transformer and output tubes (an older D-150 IIRC; my D-79 actually handled the same load) and a number of SS amps do anything from just shut down to oscillate and self-destruct, sometimes before anyone had time to react. As in, plug in, turn on, and listen to one quick squeal as the amp died. The big Krell and Mark Levinson did OK, as did a Perreaux, but some well-regarded amps like HK and Spectral did not like it (e.g. the "ultrawideband" leaders back then). Amazingly enough, my Phase Linear 700 did not blow up, and a Crown D-150A overheated (surprised the heck out of me) but was otherwise OK. My Hafler DH-200 was fine with it though ran hot. The Infinity ServoStatik (?) amp shut down immediately.
Can't remember them all now, but must have tried a couple of dozen, and most worked "ok" but most all struggled with high THD and ringing. The ringing was usually related to the output stage of the amp and the ESL's impedance so tended to spray HF energy not harmonically related to the signal. That led to "harsh" high end with some amps.
But, no ESLs, John? Not even a little pair of Janzens? For shame...
