You haven’t even bothered doing the simple calculation.Is there any progress on this to be able to bring the simulations closer to reality?
But also a dynamic amplifier model would be helpful here.
Yes, you doing an actual experiment instead of asking other people to try to justify your evidence-free crackpot claims.The simple calculation has already been made in many cases, but it does not match my and those of others perceptions, i.e. at least one component is still missing.
Not my area and I have a full-time (plus) day job unrelated to audio. They are close enough to illustrate that output impedance can influence frequency response; IME that is by far the biggest impact. The frequency response reflects the effects that things like back-EMF will have, and things like the Stereophile speaker model will generate such effects.Is there any progress on this to be able to bring the simulations closer to reality?
Here's a good counterexample that there's more to it:Still output impedance does never dominate the damping the drivers sees as long as it remains low in comparision to the driver impedance. Below 1/10th (DF > 10) it has zero effect on damping...
FTFY.Here's a good unsubstantiated, unlikely, evidence-free claim that there's more to it:
Link
Link
It shows just by a single keypress in the same setup, how the audible impression changes with different DF. I have the same experience for 30 years, but with different amplifiers. This is not meaningless to me and others.Seriously...haven't you been here long enough to realize that kind of anecdotal 'evidence' is meaningless?
Why would T + A lie over this?Who knows what that switch really does. T+A claims it toggles between damping factors of 800 and >70, whatever that means. Without measurements/investigations by competent independent parties, I wouldn't take their words that that's all it does.
They don't.Why would T + A lie over this?
I don't think 'lying' has anything to do with it. However, changing Damping Factor between 800 and 70 won't in itself change anything sonically, so if people are reporting 'night & day' differences, then they're either imagining it, (perfectly possible) or T&A are doing something else like adding audible distortion or changing the frequency response, both easily measurable. The sort of people liable to ascribe N&D differences are not the sort to impose strict controls on listening, so could be easily taken in.Why would T + A lie over this?
With an increase in frequency you would get an increase in load inductive reactance (Xl). Due to this the damping factor isn’t constant.I don't think 'lying' has anything to do with it. However, changing Damping Factor between 800 and 70 won't in itself change anything sonically, so if people are reporting 'night & day' differences, then they're either imagining it, (perfectly possible) or T&A are doing something else like adding audible distortion or changing the frequency response, both easily measurable. The sort of people liable to ascribe N&D differences are not the sort to impose strict controls on listening, so could be easily taken in.
It's all marketing bollocks!
My summing up of pretty much anything in today's world....
S
So what? As long as the DF doesn't drop below 10, it matters nowt. Especially so at HF where on a passive loudspeaker, the damping factor measured at the tweeter will be a lot lower. On an active loudspeaker it matters even less.With an increase in frequency you would get an increase in load inductive reactance (Xl). Due to this the damping factor isn’t constant.
Active or passive makes no difference, because the amplifier’s output impedance is fixed, the speaker drivers changing impedance is the one that alters with frequency. . Why would it matter if the power amplifiers are on board or not? We’re did you get the figure of 10 from?So what? As long as the DF doesn't drop below 10, it matters nowt. Especially so at HF where on a passive loudspeaker, the damping factor measured at the tweeter will be a lot lower. On an active loudspeaker it matters even less.
S
The amplifier's output impedance isn't fixed, but doesn't vary by enough to make a difference, but the output impedance seen by the tweeter includes that of the crossover, which can be enormous relatively if there's a level matching resistor in series. Even without, there will be the series resistance of the inductors, so the output impedance of the amplifier is largely irrelevant.Active or passive makes no difference, because the amplifier’s output impedance is fixed, the speaker drivers changing impedance is the one that alters with frequency. . Why would it matter if the power amplifiers are on board or not? We’re did you get the figure of 10 from?
Indeed. Do you have any figures for this with a 'typical' amp? I knew how it varied with valve amps due to very limited open loop bandwidth, but always assumed with SS amps that even if the variation was 'large', it was still sufficient even at HF and low LF or it not to have an audible effect.Amplifier output impedance (and thus damping factor) chances significantly over frequency, largely due to reduced feedback factor at high frequency. My models assume that.
