BullBuchanan
- Joined
- Mar 27, 2019
- Messages
- 132
- Likes
- 30
- Thread Starter
- #21
No perceivable difference in noise in the 10/100k input impedance switch or with the Denon x3700h in pre-amp only mode vs normal mode.Well, then it seems the issue might be the higher-than-spec gain, if we can believe the Stereophile measurements.
So the 10/100k input impedance switch doesn't make a difference?
You might just try to run the amp with XLR input to use the lower gain, just get an RCA to XLR cable (or make a decent one yourself):
just a short question here:
I want to buy (not DIY) RCA to XLR (male) cables in the ("pseudo-balanced") fashion that Hypex and others recommend (see picture below).
I want to buy ready made / 'off the shelf' cables (of several different lenght) that are of very good* "mechanical" quality,
*by this I mean good materials and well done workmanship, ("should be pleasing to my fingers and eyes") -> I do not mean any cable-woodoo silver rhodium ultra high resolution blah blah
Any quick recommendations from your experience (a link is sufficient).
drawing from Hypex Datasheet:...
- Dirk_67
- Forum: General Audio Discussions
Also: did you configure the x3700h to disconnect the amps for the pre-outs?
Connecting an external power amplifier AVR-X3700H
manuals.denon.com
What does the RCA shorting test tell us?
