BullBuchanan
- Joined
- Mar 27, 2019
- Messages
- 132
- Likes
- 30
I recently picked up two mono block ampliers from an apparently defunct USA company called Portal Audio. These models are called Paladin and we're manufactured in 2006.
I'd like to sell them, but I want to make sure they're in good working order before I do. The problem is I'm hearing an audible (from the listening position) hiss coming from the tweeters of my speakers (two sets tested). The cables aren't long enough to reach both
Here's an example of the hiss sound: https://photos.app.goo.gl/uVDcbq97UrvfsCrL9
Setup:
Denon AVR x3700h
Portal Audio Paladin Monoblocks
Speakers: Tekton Double Impact, Von schweikert VR-4SR MK2
I have the left amp and recover plugged into a surge protector and the right amp plugged into a different surge protector (same make) in a different outlet.
I just bought new rca cables to try to rule that out. I did get some audible improvement with the new cables. The hiss is now unstable and even sound where before there were crackles and the right channel was louder. Now they are the same volume and texture. The hiss does not increase/decrease with volume changes on the AVR.
When I run the AVR as an amp, it's dead silent.
Because the noise is consistent now across channels, I see two likely possibilities. Either the noise is inherent to the preout of my AVR or it's inherent to the design of the amplifiers.
I can't think of how I'd verify either as I don't have another preamp to test the amplifiers, and the amp manufacturer is no longer in business and has sparse detail on the wen outside of a stereophole review from 2006.
And other tools I could buy or ways I could root cause the noise?
Setup:
Denon AVR x3700h
