I wanted to know what kind of load Amir and others put when measuring amplifier distortion? Basically, you'll need to connect your audio analyser input or other ADC input in parallel to a high-wattage load, so that the amp can work at high volumes -- I'm referring to that dummy load. I was reading over at diyaudio, on a thread where they're discussing how to do really high-resolution distortion measurement, that the type of the dummy load resistor has quite an impact on the HD values you get, when the rest of your chain is able to measure -130dB or thereabouts. They are talking about something called thick film resistors as being the only resistors which give very low distortion.
What are your experiences?
