Amplifier Choice for Triangle Borea BR08: Burson vs Atoll vs Audiolab
I have found a single review which measured the FR and impedance of the BR08:
Using a tool to extract the data from the tiny, tiny graph at the end the impedance dips down to 2.0 Ohms at 114 Hz and stays below 3 Ohms from at least 90 to 235 Hz. At 1 kHz it's 8.1 Ohms, so the nominal impedance is correct - the minimum seems to be quite a bit lower than specced, though.
Nice review
No, it's a protection only. In my country (Bangladesh)its summer season now. My room temparature is avarage 38° celcius during day time. Though Burson is highly biased calss A and it has Class A Amplifier, it draws high current all time even remain idle. So as per my condition it's essential extra cooling system.
Thanks
Good heavens. And I thought 38° outside was bad. Stay safe mate
What better case for using a class-D than suffering 38C ambient!
The Aune looks like a 100% transparent headphone amp. The manufacturer even published the measurements on their website: -112 dB THD and imperceptible noise. Low output impedance, flat FR. I'm sounding like a broken record here, but there is nothing special about class A and there is no magic required to reproduce voltage over time with sufficient bandwidth for audio at a couple of Milliwatts.
The Aune is a clean preamp. It was much better using it as preamp on a Cambridge CXA61 instead of its volume pot. It was clearer and the perceivable depth was increased. It is not "fuzzy" at all, I will use some words that I have heard describing it as "rich" or "dense". Also a comment about measurements. They are related with the maximum voltage that the a device produces, usually it comparable on DACs as they have the usual 2v or 4v. This is not straightforward with the preamp and amplifiers. Usually unity gain measurement is used or 5watt at 4ohms, but I unfortunately not always especially from manufacturers. As there is no independent measurement also we are missing the relation of 2nd and 3rd harmonic with the fundamental frequency and the rest of harmonics. Attenuation also I think should be considered. If I try to make the Aune work at unity gain and use Eversolo as volume attenuator, I have the feeling that the sound was much closer to have the Eversolo attached directly with nothing in between if not completely the same.
As for class A yes I can agree that doesn't matter, but it is usually used on preamps as it is easier to be implemented there. My ifi Zen Can is another class A preamp/headphone amp. It doesn't sound as clean, it is more "fuzzy" instead blurring a little bit the output. It can be seen as rest of the harmonics are higher, closer to 2nd and 3rd harmonic although they decline. I am suspecting that the JFET used is to be related, although the same doesn't apply on all JFET implementations.
Interesting thread because I'm going through something related with the same speakers right now.
I have the BR08s paired with a Marantz M1 (100W + 100W @ 8Ω, 125W + 125W @ 4Ω)— which I think is in a similar ballpark to the 9000A you're considering — and power honestly hasn't felt like the issue. What I'm actually struggling with is the midrange. Vocals sound recessed, thinner than I expected, less body. Suzanne Vega's *Luka* is a good reference: her voice sits noticeably further back compared to my previous speakers (JBL Stage A170, Dali Oberon 5).
The strange part is that above 75–80 dB things actually change — the body comes back, the presence in the vocals fills in and the speakers start to make more sense. But that's louder than I normally listen (68–73 dB at about 2.5–3 meters), and I shouldn't have to push the volume that far just to get a natural midrange. Enabling Night Mode or Dialog Optimizer on the M1 brings it back at lower levels too, which is what I've been doing, but it feels like a workaround.
That's what's making me doubt whether a more powerful amp would actually change any of this, or if the BR08s just have this character and the real answer is to return them. I've already done 100+ hours of break-in so I'm not expecting that to change anything at this point.
Genuinely unsure — would love to hear from anyone who's spent more time with these speakers.
you need a DSP, a loudness button or a sub. It’s not a matter of the amp.
Some amps are leaner others are bolder, but the easiest way to improve low volume listening is by forcing loudness. At low level listening you need more bass and more treble to compensate loudness. Some old amps had that button. Others have manual adjustment. Others have dynamic loudness.
And you can set that compensation through a DSP.
But after having a DSP I still think that having a sub closer to listening position is the best way to experience late night low level listening.
Interesting. I do this as well. Having the sub close allows the level to be low enough for late night, while still being perfectly integrated thanks to the DSP's time delay.
