There are also some additional measurements with more detail on power and different loads from
hifinews.com. It is one of the few staying stable as the power increases and load is changing (measurements are THD not THD+N but some calculations can be made).
Bridge Mode was disappointing though. The website image of bridge mode is not correct. There is one hidden reflecting the officially published one (
THD bridged mode). There is no free lunch as with bridge mode the load is getting in half increasing the noise and THD. There should be an option or done automatically to decrease gain. Maybe then could had better results. Still I have seen rare cases that bridge mode can work well on 4ohm let alone lower. I tried to compare stereo mode vs bridge mode on one of my speakers (Quad Revela 2) and I much proffered the stereo mode. In bridge was less clear, although there was a hint of more bass maybe as it was getting less controlled (increased harmonics). I was waiting a much more analytical review/measurements from soundstagehifi.com too. But they have published only for 9000Q leaving the promise for 9000P unfulfilled.
As for measurements alone, they can tell something but maybe something is missing from measurements themselves. I compared Audiolab 9000P and it was much better choice than Topping LA90. I observed that the Topping having more loose bass sounded bloated on some cases/speakers. Audiolab produce more correct tight bass, that is why one year before I chose that over risking getting two Topping B200. Topping LA90 could theoretically have a more clear reproduction, but at least if you check the 20Hz protection or the recent measurements on B200, you can see the limit that a power supply can have. Purifi and Hypex options can be much safe options, especially the 1ET9040 as it can reach safely 1200 watt at 2 ohm. In the past I was thinking that those class D options where not as good as Topping offerings on high frequencies. I checked though that the situation is slightly getting worse at 10 kHz and more obvious at 15 kHZ. The second harmonics of those frequencies are not though hearable so we shouldn't care at all. On some measurements it can be observed a deep on 10kHz and beyond as they choose actually to take into account the noise only and not the harmonics.
