Hi everyone,
Been having a hard time understanding distortion and headroom for headphone amps and wanted to ask for some help to see if I have things right.
Consider a hypothetical amp and headphones. When a 1 kHz test signal is played, the combination has audible distortion when set to 80% of maximum volume, and no audible distortion when set to 70% of maximum volume. The 1 kHz test signal is a 'full scale' sine wave; the digitally-encoded sine wave amplitudes goes all the way from the minimum to maximum allowed values.
For the sake of this question, let's assume that this distortion threshold is the same for a sine-wave test signal at any audible frequencies: distortion at 80%, no audible distortion at 70%.
Does this mean that, when set to 70%, the amp and headphones will also have no audible distortion for ANY music/audio file? The internet mentions things like "crests" and "dynamic range" of music - I get that music has a wide range of output intensity but I would expect all those intensities to be lower or equal to that from the sine-wave test signals. Thus, the combination could never have any audible distortion with the volume at 70%, but may have audible distortion with the volume at or above 80% depending on the music.
Looking forward to hearing thoughts and learning if/where I've made a wrong assumption above!
Thanks in advance
Thanks in advance
