Ampapa D1 Stereo Amplifier Review
Rate this amplifier:
    Votes: 4 1.1%
    Votes: 54 15.1%
    Votes: 202 56.4%
    Votes: 98 27.4%
This is a review and detailed measurements of the Ampapa/Douk Audio D1 stereo class D amplifier. It was sent to me by the company and costs US $199.99.
Ampapa D1 class D stereo desktop amplifier with VU meter balanced review.jpg
The D1 implements one of the best graphic emulation of VU meters I have seen! The OLED display looks nicer in person than the above picture. We even have some ballistics in there with slow decay. There are other visualizations but this one looked so nice that I stuck with it. Input selection and such is performed through the clickable volume control.
Turning the volume control causes the current value to be displayed.
Ampapa D1 class D stereo desktop amplifier with VU meter balanced triggered remote power suppl...jpg
The high pass filter control on the left with off click put a smile on my face yet again. Now you can properly roll off the lows so a subwoofer can take over, or avoid pushing your speakers too hard in low frequencies.
I was even more surprised to see the 1/4 inch balanced connectors as well as trigger for automatic powering of the unit. Company was seriously listening to feedback from ASR members! :)
The included power supply opts for higher voltage than current so ups the capability in 8 ohm more than 4 ohm. In use, the power supply temperature did not even rise above room temp --- remarkable efficiency.
As you see, there is tone control buttons on the remote. I did not bother to test them.
As I was testing the unit, by accident I shorted out the positive terminal of the left channel to the chassis. I saw a spark and that channel shut down. Worried that I had damaged the unit, I power cycled the amp using front panel and it came back to life. So pretty robust protection circuit.
By the end of the testing, the amp was warm but nothing concerning. There is plexiglass on top that allows you to swap op-amps (don't!).
Ampapa D1 Amplifier Measurements
I was yet again pleasantly surprised by the high SINAD produced by the D1 in both RCA or Balanced inputs:
Ampapa D1 class D stereo desktop amplifier with VU meter RCA measurements.png
Ampapa D1 class D stereo desktop amplifier with VU meter TRS Balanced measurements.png
Ranking is up there, nearly getting into upper tier of performance:
Dynamic range is excellent as well, especially for this price and class category:
Ampapa D1 class D stereo desktop amplifier with VU meter TRS Balanced SNR measurements.png
Channel separation likewise, turns in good numbers:
Ampapa D1 class D stereo desktop amplifier with VU meter TRS Balanced crosstalk measurements.png
Company advertises PFFB implementation which means it should have little load dependency. Alas, we see more than that:
EDIT: 8 ohm label should say Ampapa D1 8 ohm, not SMSL.
Ampapa D1 class D stereo desktop amplifier with VU meter TRS Balanced frequency response measu...png
Since you have tone controls, you may be able to crudely compensate a bit for treble rise/fall due to impedance of your speakers.
Typical of this architecture, there is some rise in distortion in upper treble as indicated in multitone and 19+20 KHz intermodulation distortion tests:
Ampapa D1 class D stereo desktop amplifier with VU meter TRS Balanced Multitone distortion mea...png
Ampapa D1 class D stereo desktop amplifier with VU meter TRS Balanced 19 20 kHz intermodulatio...png
Power delivery was healthy for such a small and low cost amplifier:
Ampapa D1 class D stereo desktop amplifier with VU meter TRS Balanced Power 4 measurements.png
Ampapa D1 class D stereo desktop amplifier with VU meter TRS Balanced max peak Power 4 measure...png
Ampapa D1 class D stereo desktop amplifier with VU meter TRS Balanced Power 8 measurements.png
As you see, distortion rises more in one channel than the other. No matter what I did to my cabling and connections, I could not dial that out. While it could still be a wiring issue, it looks like a minor problem with the amp itself. Since even at highest level, SINAD is near 90 dB, I would not be concerned about it.
Sweeps of frequency vs power and distortion shows what we expect:
Ampapa D1 class D stereo desktop amplifier with VU meter TRS Balanced Power 4 vs frequency mea...png
20 Hz was too much though but I suspect none of you would be driving speakers capable of going this low with this amplifier. As I showed earlier, 40 Hz power is quite good at over 120 watts.
The "weaker" channel improved negligible amount after warm up:
Ampapa D1 class D stereo desktop amplifier with VU meter warm up measurements.png
There is a rather high spike on power on so depending on how sensitive your speakers are, you may hear that:
Ampapa D1 class D stereo desktop amplifier with VU meter TRS Balanced power on off noise pop m...png
The D1 nails the functionality I look for that doesn't frequently exist in amps at multiples of its price points. The amp while compact, is quite attractive with that nice OLED display. I did not comment on packaging but it comes as if you bought an iPhone or something! No sign of cost cutting anywhere. Measured performance is very good to excellent. The one exception is the weak implementation of PFFB to reduce load dependency.
Pricing is ridiculously low for an amp that produces whopping 170 watts times two into 4 ohm with the bevy of features we see here.
I am happy to highly recommend the Ampapa D1 amplifier. Yes, normally the frequency response load dependency would get a grade lower. But with all the other features and design, I upped my rating. You can disagree in the poll! :)
  • Ampapa × Douk Audio Collaboration: Built on the acclaimed Douk Audio A5 amp, the D1 retains core features like TPA3255 chip, HPF, PRE-OUT, socketed op-amps—now upgraded with digital VU display, TRS balanced input, Bluetooth 5.2, treble/bass control, remote and more for next-gen HiFi performance.
  • Digital VU Meters with Retro Soul: D1 features a vibrant OLED screen that merges classic aesthetics with modern utility. Enjoy 7 VU styles in classic yellow, blue, or black and view real-time feedback of all operations and playback. Both stylish and functional, it brings your music to life.
  • Engineered for True 2.1 Systems: The adjustable 30–200Hz high-pass filter removes low frequencies from the main output, letting your stereo speakers focus on mids and highs with better clarity, while PRE-OUT offers full-range signal to active subwoofers, amplifiers, or active speakers.
  • Premium Components for Superior Fidelity: Pluggable NE5532 op-amps allow for effortless upgrades, while PFFB technology eliminates load dependency, enhancing performance and sound quality. From NJW1194 chip, SAGAMI inductors, 2oz copper PCB to GaN 48V/5A power adapter, every element is chosen for sonic purity.
  • Engineered for Everyday Convenience: With a 12V trigger, infrared remote, one-touch mute and Bluetooth reset, D1 simplifies your daily audio setup. Fine-tune your sound with ±10dB tone control, while internal RGB lighting adds a refined, modern glow. Enjoy seamless operation from start to finish.
This is SO much better looking to me than the recent Douk amplifier. Really nice looking VU simulation. Nice specs too. The channel variation in measurement and poor pffb implementation are unfortunate, though, and would keep me from buying this versus the other class D current great options. But if I was mad for VUs, this design could twist my arm.
Wahoo! I already had a 3e Audio A5 which scratches my best possible specs itch, but I also like bouncing meters & the ability to adjust tone so I got one of these to scratch another (we are multitudes). It sounds great to me, no different than the 3e Audio, but no blind testing.
Potential buyers should know:
  1. You cannot turn the display off, you can only change what it shows and dim it. So, no timed display off option like many amps.
  2. The original release has no signal-sensing power down, which matters as the display does not turn off. It does have a 12v trigger (see below) Bipolarbear writes that a newer D1 release (V1-1 dated 2025/11/12) has a defeatable 5 second signal sensing turn on/shut off that works without a long delay.
  3. The display, looks great but does not have a totally black background, its LCD not OLED. There are six meter styles, a spectrum bar thing, as well as a function (input volume etc.) option. Everything is accessible from the remote
  4. The rear 12v trigger takes a 3.5mm stereo plug. This is not directly compatible with my WiiM Ultra which uses a 3.5mm mono plug. I tried stereo to stereo and mono to mono cables that did not work. What did work was a 3.5mm stereo cable with a 3.5mm mono to stereo adapter like this at the Wiim Ultra end. The trigger works fine and instantly.
  5. For me the tone controls (+- 10dB) are useful, and can be easily zeroed out as their setting shows on the display.
  6. As Amir says, its a very handsome unit in person. The chassis is aluminum, it all looks and feels premium for the price point.
  7. The D1 and the Aiyima A80 Amp/DAC share the same Original Design Manufacturer. Not identical, the D1 has no DAC, the A80 no LPF or internal illumination, but size, features, and measured performance are similar.
At last, a way to protect my 60 year old EMI SPEAKERS and my baby linkwitz without spending 2000 on a denon with decent sinad. Come on , balanced inputs , meters, tone controls...next thing you gonna tell me is that tariffs have been lifted and prices are falling....do u have any bridges for sale??
DOUK RAIDER....May the force be with you.
Only Like 5W at 20hz?!
Would be interesting to see at what frequency it can deliver significant power.
But the test only shows 4 ohm? so we can’t see how load dependent it is?
Looks so good for a budget amp, they got it right, there. Performance is a lil bit disapointing, the competition's just too good.
No, it produced 90 watts. Then went into protection which caused the line shoot all the way to the start.
I did show the 8 ohm in green albeit, forgot the change the label from SMSL to Ampapa:
Had it for a couple of months now connected to a fiio k11 r2r and some Dali spektor 2 for my desktop… really enjoy the sound of it …recently put in a pair of virtual hifi supersonic v2… to my ear it def sounds better than the stock amps but concerned how hot they get inside the unit.. and long term issue maybe
With so much in the way of "bang for the buck" value delivered by this thing, I'm at a loss as to why several of these apparently very capable companies can't manage to implement PFFB properly. That wouldn't pose a problem for yours truly -- I'm 78, can barely hear 10 kHz, and have no use for this particular product -- but IMO there's clearly an issue of "so close, yet so far" here. :(
Yeah, we do have a few good ones that Amir has tested, though. (I'm hoping the new Fosi BT20a MAX will get tested soon and that does well.) The Topping Mini 300 really nailed that measurement recently...
2. There is no signal-sensing shut off, which matters as the display does not turn off. So, using the 12v trigger really mattered to me.
3. The display, at least on mine, looks great but does not have a totally black background. There are six meter styles, a spectrum bar thing, as well as a function (input volume etc.) option. Everything is accessible from the remote.
4. The rear 12v trigger takes a 3.5mm stereo plug. This is not directly compatible with my Wiim Ultra which uses a 3.5mm mono plug.
5. For me the tone controls are useful, and can be easily zeroed out as their setting shows on the display.
One correction. I have a stereo 3.5 trigger cable, and it connects Wiim Ultra to D1 without any issues.
That is odd. Stereo cables connect (I can plug them in) but they did not work. I tried 2 different stereo cables between the D1/WiiM Ultra, same result. I just tried again (in case there was an Ultra firmware fix) it still does not work.
The problem is discussed on the Wiim Forum relative to Aiyima amps (which have a connection like the D1). The official solution from Wiim is to push the cable only 1/2 way into the socket. I did not try that but it does not seem as if it would be stable. So, if yours works, great, if not, the adapter is the solution.
A little piece of 3.5mm ID tubing to limit insertion depth might be enough to stabilize "the official solution".
