Ampapa D1 or 3e audio A7/A5
Status
Not open for further replies.
Yeah, this dude talks about how an op amp works and all the stuff inside and how PSUs and capacitors matter, "attention to detail", bla, bla, bla. But what matters is what comes out of the device: You can build the nicest looking amp with lots of caps with the best PSU and still deliver a shit sandwich at the output. A layman (me included) simply can't tell by looking at a PCB whether it will perform well and if all the good caps are in all the right places. This video is misleading at best.
To me that just reinforces the correct conclusion: "don't bother rolling opamps".
He is just giving the details on WHY that is correct.
I would never trust anyone who says there is no difference in sound quality when comparing an NE5532 and an Muses 02 for example and even go as far to accuse the manufacturers and consumers for that matter of snake oil.
I understand circuitry requirements etc and the argument is not against measurements but I think the boys and girls on here know my stance by now.
RandomEar,
First of all, I want to say I appreciate your thoughtful responses and the dialog.
In my head, I'm not necessarily convinced on all the arguments, but I'm certainly no engineer, just seeking to understand better how things work and questioning things when they don't make sense to me.
I know that this is AudioScienceReview and I do see plausible scientific explanations on what I am hearing.
For me, ultimately, this is a hobby and what my ears prefer is what gives me enjoyment (not sure why some users on here think anything put 100% accurate is stupid unless they also believe in not seasoning their food) despite it not measuring as accurate - so I want to learn about what might cause sound to change, even if it is adding second order harmonics, distortions and color.
Soldering op amps would be more reliable and even give a miniscule performance advantage due to less contact resistance and less stray capacitance. From an engineering perspective, it does not make sense to socket op amps (outside of testing and development environments). It's a pure marketing/sales driven decision.
Marketing/sales...yes, could very well be. That's why I'm so interested in this topic.
A) You can design transparent devices using NE5532's.
Agreed.
You can improve designs further concerning noise and distortion, even if they are already audibly transparent. Again: I didn't say there are no better op amps than NE5532 - there are. Even if they sound the same, an amp with lower THD on the spec sheet might simply sell better.
Ok, so your condition is that is it already audibly transparent. So we are talking about the diminishing returns (or in fact no more returns after you reach audible transparency).
But let's say the circuit is not audibly transparent...
I do get your point about circuit stability - being somewhat binary (not your words, but how I think about it) or not, but would this depend on the overall environment and operating conditions? So it might be stable in 90% of the perfect operating conditions but maybe perform worse if one or more factors is outside of range?
And of course this is a layman's view - but wouldn't heat, noise, voltage, current over time impact stability? If the circuit is not perfectly designed to always supply the opamp with ideal conditions, I would imagine it could impact the sound. We have PSSR, output impedence, input offset voltage, slew rate, gain bandwidth etc...
Is it not possible to design a circuit to take advantage of an opamp better specs in these categories for better sound (assuming its not yet audibly transparent)? ...Even if that same circuit would still be stable under most conditions with an NE5532?
I take your point on improving things that are beyond our sensory capabilities, but I do keep hope out there that we don't know it all yet and that some cool new science/innovation will improve our experiences even further that we didn't know about. Otherwise there would not be much to look forward to.
Again - really appreciate you sharing your thoughts with me.
Cheers.
RandomEar,
My pleasure. Thanks for a friendly discussion.
I get it. Ultimately we want to appreciate well rendered music. For me, the goal of ASR is to offer people good information to approach this in an objective, bullshit-free way.
Agreed.
Yes. If I remember correctly, Amir qualifies "transparent" as SINAD better than 115 dB and +-0.5 dB from 20 Hz to 20 kHz. From my point of view, CD quality should be sufficiently transparent for almost any application - that would be 96 dB SINAD. Almost all DACs and most amps today surpass that threshold for "almost certainly transparent".
Stability is mostly an example of what you could make worse by swapping op amps. There are three types of stability for linear systems: Asymptotically stable, marginally stable (rare in practice and just as bad as unstable for audio applications) and unstable.
Stability is not really a concern for music reproduction because you won't use an unstable or marginally stable amp for that - it would immediately screech your speakers to death.
It's hard for me to imagine a system that close to the border of stability in an audio device. As noted above, stability is not something you usually need to worry about. And definitely not with prebuilt amplifiers.
The properties of semiconductor components are also guaranteed within their operating temperature windows, which are usually uncomfortably high for normal amps - 150 °C are not uncommon for mosfets and such.
An amp either has bad distortion in its default state, or it doesn't. The measurements can change slightly when heating up, but from room temp to 50 or 70 C inside the hottest chips, the change isn't order of magnitude.
Higher currents are similar: As long as you stay within the rated limits of the main chips, it's fine. Distortion over power plots tend to have that extremely steep increase close to the rated power. Before that, not much is happening.
Maybe? Ignoring stability, I would expect that in a bad measuring amplifier the op amps are typically not the performance limiting factors. But if distortion were already audible due to bad circuit design, a different op amp might change the distortion profile.
But we are taking about "bad, bad" in this case. As in: tube-like -45 dB distortion. That's not something you will encounter in any modern transistor or chip amp.
That's also why I'm that adamant about op amp rolling being useless. This thread is about the Ampapa D1 and the 3e A5/A7. We have data for the 3e amps and it shows a SINAD of better than 100 dB for both. That's better than what audio CDs can reach (!). From my point of view, that's transparent. There would be no point in rolling for these amps. The same is true for most modern amps.
I don't think "audio reproduction won't get any better if you select these three devices because they are essentially perfect" is a bad outlook. A bit boring maybe, for people who like to constantly change their setup. But you could still look forward to listening to all that new music that's still to come :)
Cheers.
Cheers.
He certainly is not stating there cannot be a difference in the sound quality. He is saying if there is a difference, and you the user prefer the change - which would need to be backed up by blind calibrated ABX testing to be asserted as real - does not mean there was any **objective** improvement in actual quality.
Human hearing is a much more precise instrument than any electronic device.
Not really. Most ears can't do CD quality, 20hz to 20kHz.
And most speakers can't replicate it either
And even if you listen to 24bit recording I guarantee that the microphones used are nowhere near that kind of quality.
And then we have poor SINAD speakers, which is basically all of em
That video is indeed very educational and informative.
Rolling opamps is stupid, was my takeaway.
I think you are right on both points. I am glad to see it discussed here because the video was very frustrating for me, and it probably misleads most YouTube viewers. You were not mislead.
Analogholic appears to have an electronics engineering background. The first 3/4 of the video appears to be an objective explanation of what Op Amps do and how they can impact an amp's sound. Just "appears" because I do not know enough to judge accuracy, but I learned a bit.
Things go off the rails at 27:20 when he applies op amp theory to actual Fosi V3 Mono amps. "Socketed Op Amps.....indicate the designer is inviting you to tinker rather than delivering a fully optimized design." He then hears a significant improvement when he substitutes a different op amp and determines the cause was unoptimized circuits in the V3 Monos. This is wrong.
Fosi is certainly inviting you to tinker. But, we know for certain from V3 Mono Testing by Fosi and several others that the design is fully optimized. None of the possible issues Analogholic describes occur in this circuit. The output of the V3 Mono is transparent within the scope of human hearing, and is load independent. Substituting a different op amp cannot not make it better. Yet, Analogholic heard a significant improvement when he substituted a different op amp and determined, without evidence, that the cause was an unoptimized circuit.
The possible problems Analogic raises are not theoretical, Amir has tested TPA3255 PFFB amps that are not transparent or load independent. But that is not true of the V3 Mono and testing the entire system is far more reliable than examining individual Op Amp specs and plugging them in for sighted subjective testing. That's nuts.
I commented on this and received a polite reply from Analogholic (appreciated) and negative one (expected) from Jeep_On "Thank you for regurgitating the ASR mantras. I used a different model, the ZA3's, but the differences are not imaginary or subtle."
This is where the video misleads.
All human hearing is imaginary in the sense that all hearing is predictive and biased. Blind testing reduces the bias. The fact that minute ACTUAL changes in output are heard as obvious and substantial in sighted swaps proves only that predictive bias real, all encompassing, and not subtle.
This is where the video misleads. All human hearing is imaginary in the sense that all hearing is predictive and biased. Blind testing reduces the bias. The fact that minute ACTUAL changes in output are heard as obvious and substantial in sighted swaps proves only that predictive bias real, all encompassing, and not subtle.
I originally checked out this thread to see if it made any sense to sell my 3eAudio A5 and down/side-grade to an Ampapa D1, to save some money and get a remote control along with some visual bling.
Instead, I ended up just adding a Fosi Audio P4 preamp.
I agree all hearing is biased - its all psychoacoustic... one of the reasons is to protect us in the wild from predators and danger, so our brain will interpret the waves and accentuate certain aspects to give us a sense of distance, location etc for survival.
Based on that alone, hearing will never be objective, always subjective - but that's what we have - you're not going to bust our your tools and take measurements before you decide to run, or take cover, or you'll be dead. Same goes for enjoyment - you either enjoy the music or you don't, you don't need an oscilloscope to tell you that.
That being said - given we have biases and subjective, - truth and transparency can only be achieved by measurement.
So I did try a little experiment. I'm not an engineer. I don't have sophisticated tools. I just downloaded HouseCurve on my iPhone and took some measurements.
The P4 has 1 socket, and comes default with NE5532 - I just did the sine wave sweep with my iPhone on a tripod positioned at ear level in listening position and took measurements, rolling every opamp I had. NE5532, OPA2156, MUSES 01, MUSES 02, SS3602, Burson V7 Vivid, SS2509, OracleII-02, SuperSonic V2 and so on.
I measure each one twice, and the measurements were consistent.
Most opamps were quite generally similar in their curves (probably because of the room modes), but I did get differences in frequency response, some quite significant.
Now this doesn't tell me the impact of noise by swapping opamps, but it does seem to indicate that the opamps are impacting the frequency response. I'm so curious now, that I'm tempted to get a Wiim Ultra for the room correction and a UMIK so I can test everything again.
I was expecting to get similar graphs on the sinewave sweep based on the all the comments on opamp swapping not have an audible impact on the sound....
Good on you for experimenting. Concening your measurement setup, an iPhone is definitely easily accessible for many. It is also not that precise. I would therefore not conclude that the differences you observed are definitely present. Nonetheless, I would encourage you to upload the measurements here (maybe in a new thread) for us to see and discuss.
In general, I would not measure the response using a microphone because deviations of even a couple of dB are essentially all within the uncertainty of the measurement. External factors like noise from outside of the house, your position in the room, open or closed doors or the AC kicking in all affect measurements with microphones. For that reason, a measurement at the speaker clamps using an ADC and, if required, a level shifter will be much more precise and should be preferred.
I agree that human hearing is extremely subjective, psychoacoustics rule.
Whatever one says about any component change is inherently suspect, including "I prefer X over Y"
unless backed up by stringent volume-matched and statistically valid ABX testing, even if only for just you as one person.
"This sounds better" more generally requires the above, but with a large sample size of people participating.
The striving for acoustic "accuracy" through measuring with technology is also "scientific" but a very different approach from the above.
I like the idea of combining both, not being dogmatic about either.
Unsubstantiated "I prefer X over Y" statements are IMO largely to be ignored unless the person is a proven god of audio ;-)
But "this sounds better" as if being declared for all humans is IMO worthy of contempt.
Status
