Ampapa D1 or 3e audio A7/A5
I don’t understand this argument. Is this rooted in science? or is science only selectively applied when it suits someone’s narrative?
I understand that in a few tests Amir has done with a few opamps, swapping them in the circuits did not result in any meaningful meaurable audio improvement. Fair enough.
But from this, can we really generalize that all op-amps swapping doesn’t make any audible improvement? (not saying you said this - you did word your reply very carefully, but i believe many people jump to this generalization)
Op amps have different electrical specifications- slew rates, bandwidth, input offset voltage this is fact. If its these differences that can make a audl device sound worse, then shouldn’t it be possie for a more correct/better matching opamp to improve sound? even if its small….
There are a number of measured comparisons on this site that show no audible differences with op amp rolling. As we know, subjective opinions are essentially meaningless due to psychoacoustic factors. Of course it is 'possible' for audible differences in frequency response to exist, but you're going to have to prove it with measurements, to be believed here. So far there is no evidence.
The price of the 3e is because it uses two TPA3255 chips in a dual mono PBTL configuration. It makes the amp stable at 2 ohm loads, but I agree that is is pretty useless for most people.
Within the context of clean high SQ amplification I am looking for the absolute highest power - and especially CURRENT - TPA-3255 amp out there, even if I only get a few incremental dB SPL. So far the 3e mono A7 is my top choice, never mind the "high cost".
48V 10A PSUs assumed, even a little higher if appropriate.
Does anyone think the D1 (or any other TPA-3255) amp out there would match that wrt that factor?
The bass management would certainly be nice icing on top if so.
It’s pretty easy and cheap to answer your own question. Buy an Douk Audio A5 and a handful of similar specced op amps ie all dual not single, fet, discreet, bipolar and have yourself some experimental fun.
I have personal favs as a result of this method of testing and have no regrets.
Measurements by themselves cannot tell the whole story, absolute accuracy is a myth in audio and in fact is far from an important factor to prioritize, within the context of modern high quaity gear.
Human preferences are valid and important.
But controlled statistically significant ABX testing is required to eliminate placebo / bias effects, to prove that a given change (in anything) does actually deliver "an improvement" even just wrt my (valid) personal preferences.
Doing so is a challenge, but well worth it, for science.
I get this...but to play devils advocate; many claim any differences you hear are just psycho acoustic since they don't show up on the measurements...
Since I can't measure it using my methods, it's not possible for there to be any real change, and any differences heard are purely in the listener's mind.
Is this just bias-confirmation?
Or are we being arrogant in assuming our current methods of measurement are infallible and complete and there's something else in audio we don't know how to objectively measure that impacts sound.
Just look at Schrodinger's cat...the act of observing can determine state.
I'm keeping an open mind and seeking more convincing evidence.
I have 3e Audio A7 stereo version. For tone controls you have some choices like Equalizer APO with Peace GUI which would be my top choice or Fosi audio preamp ZP3. It can push some serious voltage to your mono amps for sure and it has tone controls, pretty decent.
My question here is strictly about the power & current delivered by the **power amp**.
HPF for the main stereo pair and sub output are irrelevant, pre-amp issues more so.
THAT is a myth.
For power alone I don’t think the D1 will cut the mustard for you. I think the 3e will deliver more.
I actually sold my D1 on as I needed just a little more power and all round punch.
I bought a second hand Audiolab M-PWR power amplifier and now run it with a Fosi Audio P4 (Muses 02). Considerably more overall power and delivery @ 40wpc RMS.
I would like the ZP3 but just not keen on what Fosi have, imo, fallen short on in regard to design on that model. No easy access to the PCB for tweaks and dodgy volume pot.
(I was looking into the Topping Pre90 but now knowing what the Fosi P4 with the Muses 02 is capable of I am not sure the asking price of the Topping is actually worth it.)
ZP3 mk2 might revise these well noted short falls and if so I would not hesitate to buy one but for now the P4 is sufficient, a very clean sound from both the P4 and M-PWR.
There is a couple of M-PWR amps on ebay UK at the moment for around the same price as the 3e A7. The M-PWR is an easy recommendation over the 3e in every way and maybe the 3e (for power) over the D1 but can’t say for sure as I wouldn’t spend that kind of money on an Ti3352 chip based amp in the first place.
I would agree that the 3e A7 is probably slightly more powerful than the D1. But the M-PWR delivers just 60 W into 4 Ω, so most TPA3255 amps will have at least three times as much power, with the A7 reaching a factor of four.
I tend to repeat myself here, but gain ≠ power and input sensitivity ≠ power.
[/QUOTE]
tx
Here Adcom GFA-555s go for just as cheap, bit more oomph ;-) but to each their own.
Pretty sure A7 mono will be enough for me.
Do you mean TPA3255 ?
I think they're cheap! but in this case I need to use DC input, and am not that au fait with car audio gear...
tx
[/QUOTE]
Yes, the TPA3255. Sorry bad eyesight and on the go post.
It was meat on the bones for me with the M-PWR over the D1, not how loud.
I rarely get to 12.00 o’clock on the P4 using the PC and Apple Music. In the 50’s on the Fiio SR11 with a pair of Q Acoustic 5020 @ 6 ohm.
I also have a smallish room at 4 x 4m and it’s more than enough.
Also I think basically the TPA3255 has its sound now and it’s universal. It does not change much at all from one implementation to another so kind of good in one sense that you know what you are getting regardless but also predictable.
I liked the Aiyima A70 for output power, it’s pushes quite a lot out for some reason more than some of my other TPA3255 amps.
Just watched a great video on YouTube from Analogholic which explains the context of opamp rolling and what we are hearing when we are rolling op amps.
After reading more threads on ASR where this topic has been beat to death I think I get it now - the truth (as I understand it lands in the middle)
- opamps themselves do not have an inherent sound, but in conjunction with the demands a circuit places on it, can impact the sound
- often the circuit designed, operates within the specs of the opamp, and therefore rolling opamps may not have an positive impact on the sound
- in fact, when you roll-in an opamp, that might be under-spaced based on the circuit demands it can sound worse
- only if the circuit is placing demands on the opamp out of its tolerances, you may see an improvement by rolling in an opamp which has more suitable spec tolerances based on the demands of the circuit
My takeaway is yes, opamps can change the sound (for better, same or worse) depending on what the circuit is demanding and how the opamp can meet those demands (not just placebo which is the default response that is overused), but often won't have a positive effect unless the circuit was designed to take advantage of the characteristics of the improved specs in the opamp.
I'm just glad I am not crazy. I have no conscious bias of whether an opamp makes something better or not. I just use my ears to listen and let my experience make the decision.
Most times I don't notice any change.
But many times I do notice repeatable changes...just didn't like people telling me it was just placebo, especially when thousands of others have the same experience ( I doubt we are under some mass hypnosis when we don't know each other).
This explanation is based on logic and science and seems highly plausible and probable at the same time.
That's just the same wrong idea worded differently.
What would "under-spaced" even be? And why would the original circuit designer install the wrong op amp?
Either the op amp fits and the circuit is stable, or it will oscillate. If it oscillates, you will know immediately. There's also characteristics like voltage and current noise, bandwidth and distortion. But all of that has been considered by the PCB designer who - in stark contrast to you and me - knows what properties the op amp needs to possess.
Let me be very clear: You do not know what specs the op amp in that circuit needs to have. The designer who put the op amp there does know. He selected a correct op amp. You can only guess randomly and are extremely likely to make the circuit worse.
If the device already measures better than human hearing, no op amp in the world will improve the sound in any way - even if it may measure a dB better in noise or distortion. Pretty much all DACs and many amps sold today do perform better than our hearing already.
This idea that an op amp, capacitor or any other part which is "better" in some obscure way or more expensive would improve the sound in a device which is already better than our ears is just nonsense. You need to let got of the idea that some "better" part - which you do not even understand in detail - can improve an already finished device. What counts is what comes out of the output jacks. If individual parts like ICs are "cheap" or "bad" in your mind is irrelevant, if they perform as designed and the output of the DAC/amp measures fine.
Using the cheapest NE5532 can result in a circuit which is better than human hearing. You will not audibly improve that circuit, no matter how "good" or demanding or whatever the op amp of your dreams performs.
As I'm sure has been explained to you already, this is not how bias works. It is irrelevant what you expect from a comparison, results of sighted listening are biased.
Unbiased results require blind testing and fast switching times (single digit seconds). Ideally double blind ABX testing. Everything else equals a coin flip.
This has nothing to do with "crazy" or "stupid". Human senses are easily fooled, it affects us all. Clinging to the idea that you can't be fooled for some obscure reason would be borderline crazy, though.
It's irrelevant how many people repeat these claims, as long as they suffer the same bias and are victim to the same logical fallacies as you.
Your explanation conveniently ignores the well understood science, which is discussed in this forum at length. It also has multiple logical flaws, some of which I have explained above.
I don't agree with your opinion on that.
Not sure you would say that...as if all circuits or part selection is infallible. If that were the case, we wouldn't need to test gear, it'd all be good.
Could be many reasons:
1) To hit a price point... NE5532 might do the job a a basic level of performance, rather than design a higher performing circuit that requires more exotic parts
2) Scalability... allows them to get a product out the door that performs well, but builds in enough headroom to take performance further with opamps with better specs so that users have upgradability
Manufacturers can always solder the opamps right to the circuit board, they don't have to put in sockets to allow op amp rolling, but many do.
Why is that the case if they are not supporting/encouraging op amp rolling? Many even give you a choice of opamps to configure with their device too.
If you say they would never design a circuit with this in mind, then why do they?
You're just repeating what was already in the video I am referencing. I don't think we are disagreeing on this point.
If what you say is true, that for audio, an NE5532 is all we will ever need...than why do manufacturers even bother to design other opamps intended for audio use that have a broad array of specs that are better than the NE5532?
I do agree it all revolves around the design of the circuit but....how do you know in their design, they don't want to push the beyond the boundaries of what an NE5532 can do?
If it were such a commodity at such a lower price, there would be no market for better performing opamps in audio. Every manufacturer would just use the NE5532 and be done with it. Reality is many do not use the NE5332, so I'd love an explanation.
Yah, I don't disagree with you here on how bias works, but I am also not a fan for using it of to explain everything we can't yet measure or think we understand.
Purist claim Class D was not harsh for many many years, we are not hearing what we are hearing - placebo, bias whatever.
Reality was the testing was incomplete. Didn't cover cases where load fluctuated and now we have amps with PFFB to address that and know how to measure it.
I'm a believe in science, but not a believe we know how to quantify everything we do not yet understand, or that we even have a complete understanding.
There's always newer science that proves the old methods were flawed. Keep an open mind.
Where's the difference between "the properties of the op amp change the sound" and "the interactions of the op amp with the circuit change the sound"? How the op amp interacts with a circuit is governed by it's properties.
To a degree, yes. But why would you assume that precisely the op amp is the problem? And why would changing that component alone improve the whole circuit and especially improve it to an audible degree? That's where it fails for me.
Socketed op amps are 100% marketing. Look at yourself: It essentially becomes part of the audiophile hobby to change devices and "tune" them by switching components. Socketed op amps are an incentive for you to buy the device.
Soldering op amps would be more reliable and even give a miniscule performance advantage due to less contact resistance and less stray capacitance. From an engineering perspective, it does not make sense to socket op amps (outside of testing and development environments). It's a pure marketing/sales driven decision.
EDIT: Which video?
I didn't say you don't need other op amps. I said that:
A) You can design transparent devices using NE5532's.
B) If a device is audibly transparent, you cannot improve the sound any further, no matter how much better another op amp may look specs-wise.
That doesn't mean we don't need anything other than 5532's. For certain circuit designs, other op amps are more appropriate. Some may have a higher currently noise but lower voltage noise than an NE5532 and the PCB designer calculated that this would give him a performance advantage in his specific circuit. Good. Doesn't mean it changes the sound, but it will still improve the specs. Other example: A 5532 might cause instability in a circuit, while another specific op amp doesn't. Choose the stable one - good.
You can improve designs further concerning noise and distortion, even if they are already audibly transparent. Again: I didn't say there are no better op amps than NE5532 - there are. Even if they sound the same, an amp with lower THD on the spec sheet might simply sell better.
And there is even more marketing reasons. Stuff like product differentiation is a thing: Selling a cheaper version of your amp with NE5532's for price conscious customers and a supposedly higher end version with "better" caps and op amps. Because in the audio market, superstition rules and many, many buyers think more expensive components must sound better. It's silly, but it sells.
The way you talked about bias in your last post would definitely be something I wouldn't agree with. But maybe we're not that far apart on the ideas behind it.
My main problem is that a common subjective audiophile theme is that people claim to hear something and therefore it must exist / must be true. But they fail to provide any verifiably evidence. In science, the burden of proof is on the claimant - and for good reason. Since it's been proven that our senses are easily fooled, the most plausible explanation if someone claims something extraordinary is that it's just another case of fooled perception or bias. That assumption holds until any objective evidence of the contrary is provided.
The designers knew how load dependency affected the output. This wasn't some unknown effect or couldn't be measured. Testing wasn't incomplete. To the best of my knowledge, load dependency was an accepted engineering flaw of those amps. Maybe it was a cost-driven decision, maybe PFFB wasn't understood well enough to implement it broadly, maybe there were other reasons.
There is always new science. But once you reached a threshold in measuring capabilities, you don't unreach it. We can measure better than human hearing in all aspects, be it distortion, noise, phase or frequency response. And not by a little - orders of magnitude better than human hearing.
People can hardly detect -40 dB THD in controlled testing with real music, only very few lucky people reach slightly below -50 dB. Modern measurement equipment easily detects -120 dB THD. That's over 3000 times more sensitive than human hearing. These are the scales we're talking about here when I say "measurements are better than human hearing".
There may be some complex aspects which we can measure, but not interpret or connect to human perception, yet. Mostly with speakers and headphones/IEMs. Like, what quality results in people perceiving that a speaker "vanishes" in a room? We can fully characterize the speaker, room and reflections but might not know yet which exact measured property causes that perception.
Amps and DACs are not as difficult to characterize and their interaction with other components is more limited and easier to measure and especially easier to model. Not having mechanical parts makes them way easier to predict.
That video is indeed very educational and informative.
Rolling opamps is stupid, was my takeaway.
Unless you are just looking for "lower accuracy" changes you might "prefer" - which is IMO stupid, and certainly goes against this website's ethos.
I suppose just like rolling tubes?
But I would love if the actual content of the video could be critiqued, rather than a member's interpretation
