Ampapa D1 Issue with "No Signal"
lozoyad
I just got this little amp. Seems well built, love the display options, 12v trigger, low pass filter and such and sounds fine, however, I'm thinking of sending back due to a re-occurring issue during playback - it goes into a "No Signal" mode. I was playing a loop of music to warm it up yesterday (just got it) and it would stop playing and the display shows "No Signal". I can wake it up by pressing a button on its remote. Its getting a pre-out signal from a FIIO K9 via XLR. I have a couple desktop amps in my existing desktop setup that I have been swapping out (Fosi ZA3, Topping Mini 300) but this is the first one with this issue. Nothing changed in the setup except swapping out the amps and L/R cables XLR (ZA3) to XLR/TRS (Mini 300/D1). Of course if I can't find a fix, its going back.
Anyone else encountered this?
It shouldn't happen during playback, it's at least never happened to me when I've been using it. It only goes into no-signal power-saving mode after a few minutes of no signal in at all.
There's 3 variations of the Ampapa D1 (and, maybe more). The initial release, which I purchased in Dec 2025 didn't have any sort of power-saving feature. Another variation, which appears to be what the OP here may have purchased, will display the "No Signal" message after 5 minutes of not having a signal present. The 3rd version features the ability to disable the power saving feature under settings. The most recent purchase I made, has the 2nd version that I describe. I, too, experienced the "No Signal" message during low playback volumes. I communicated with Douk/Ampapa support and they had me try some exercises. Mainly, the best way to handle this scenario is provided with this quote from support: "In this case, we recommend keeping the source volume around 80 and adjusting the amplifier's volume according to your listening preference."
In my case, I reduced the amp volume settings on the Ampapa D1 to 70, then used a higher volume setting coming out of my Topping D5 II. This has mainly resolved the issue with the exception of last evening where my wife was listening at quite a low level and the amp went to sleep. I'll perform a few more adjustments to ensure that even during very low level listening, the "No Signal" message isn't experienced. Basically, a similar issue was happening to my 3E audio A7. Fortunately, 3E audio was quite active on this forum and collecting feedback so they could apply some additional adjustments to the feature to extend out the time for the amp going into sleep mode.
