Amp with bass management,eq
gasolin75
Denmark
Not shure if it's best to post it here, general audio discussion or where most post questions about subwoofers
It's most about an amp so i decided here
Triangle tituz ez and a small Argon Audio MALMÖ SUB 6 (new) amp Marantz pm 6007
I tested the bass with a simple youtube test and i still have a lack of bass at 75-85 hz
Nothing i really can do to adjust it because if 75-85hz or 70 to 90hz to cover a wider range has to be raised it's not possible
All the sound would be raised if i raise the volume of my sub if i have it at 100-90hz, bass eq, tone controsl on my amp is 50hz
so basically i need bass management to be able cut the bass from my front speakers at 90 or 85 hz and be able to adjust the bass at 70-90hz + mabye something auto room correction or time alignement from an amp, since i can't connect a cheap dsp unit to my amp, where do i take the signal from + where do i after adjustments connect the sound from a dsp unit to my amp ? (needs to work with a turntable,cdplayer,tape deck and pc)
Arylic Arylic B50 should despite the low price be able to do it (high pass filter and eq)
Wiim amp can do it but is alot more expensive and lacks inputs
Marantz NR-1200 should be able to do it but it's much more expensive than a Arylic Arylic B50 + a Wiim amp and some say it's missing something sonic in the midrange and highs + lacks some oomph (didn't find a use amp) https://perfectacoustic.co.uk/marantz-nr-1200/
What else are my options ?
WiiM Amp (or Amp Pro) makes the most sense.
In addition, having a UMIK-1 will make subwoofer integration and room correction 10x easier.
For more inputs, consider keeping the Marantz and pairing it with a WiiM Ultra.
IM NOT gonna buy a umik-1 mic for god knows how many times, it's super expensive for how much you are gonna use it
Can't find the wiim amp pro for sale, both have to little inputs = one extra unit to connect all sources
Arylic B50 is a cheaper alternative but is that really the only option ?
So you want to do subwoofer integration by ear..
Ok
Like cave exploration without a flashlight :D
Exactly !
:D
Peace.
Is something like the Dayton Audio MM6 calibrated mic still recommended? Much cheaper
Yes, for finding and fixing problems in bass any decent measurement mic is sufficient. The UMM6 should be fine as it can be used with free REW software.
