Hi everyone and Happy Easter!
Let me start with making clear that I'm swedish..so have some patience with my english.
Tomorrow I'll be installing a new system i my livingroom. It will consist of a Wiim Ultra, two Apart Champ-2 power amps where one will power a pair of Canton Ergo 620 standmounts from the preout-sockets and the other two Klipsch SPL-120 subwoofers that I have converted into passive subs since both of the built in amps have died.
I have some questions on amplifier gain och channel balance. The power amps are 1V/10kOhm at the rca inputs and the Wiim preout can be set to either 1V or 2V so my initial plan was to set the output to 1V and the amps gaincontrols to max as it would give what I've read is "unity gain". Then I started to read forums.. Some say that I'm right and thats the correct way. Others say definitely not since hiss will be elevated with gain on max. I've also read that if I dont use 2V from the Wiim pre out it will degrade performance significantly..
I know that many in here are close to experts so how would you set up a system such as mine?
I'm not to concerned about the subs. I'll just twist the knobs until I get the level I want and if right and left differs a little I probably wont here it. The fronts though.. If I'm not using the amp with full gain, how can I be sure that I get the channel balance right? I dont trust my ears more than I trust that the gain controls track perfectly so I'm a bit lost.. There are no steps in the controls so getting them identical wont be easy.
Should I play some white noise and measure in front of each speaker with a dB-app? Measure voltage with a multimeter at the speaker outputs?
Questions, questions.. Please help me make the most of my system.
