Hello,
I'm completing the setup of my main bedroom, which already consists in:
Purpose of this post is to identify 'the point of diminishing return' (or 'inaudible return' may I say) regarding the amp choice in my particular context.
Indeed, although I carefully red many of the excellent amp reviews here, it's sometimes difficult to 'weight' the results for a specific context and identify 'where to stop'.
Basically, I'm willing to pay for audible improvements, but for audible improvement in my particular context only. For example, should an amp have audible distorsion at power levels I will never use, that's not a concern for me.
Until now, I was considering an Hypex Ncore NC122MP in a Ghent Audio case that I can get for 260EUR second hand...
The room is 14m2 (152sq ft) / 35m3 (1245cu ft).
It's located in 1993 apartment and my neighbours have the same layout, which means:
The Whardeale Linton's measured sensitivity is 85.1 dB (avg. 300Hz-3kHz for 2.83V measured at 1m) as per Spinorama.org.
Their impedance can drop to 3.5ohms and minimum EPDR to 1.7ohms (!):
(Graph from Erin's Audio Corner)
Please note that I had to put the speakers very close to a wall, which is proving massive (about 8dB) of room gain around 46Hz.
That's something that will corrected with EQ...therefore asking less power to the amp in this frequency region.
Many thanks for your help!
Fred
- WiiM Ultra (90% of what I'm listening too)
- Old Technics turntable, modded with an embedded RIAA preamplifier (10%)
- Wharfedale Linton Heritage 85th Anniversary
- Where I live, 90's buildings are built in reinforced concrete which is very good at transmitting bass and infras. Hence, I will never add a subwoofer
- During the evening, I will listen at very low volume, likely with a specific EQ on the WiiM Ultra.
- During the day, I will listen at moderate to normal volume (I have to do some tests, but probably no more than 75-80dB/edit: I guess it means about 90-95dB peak, right?)
Fred
