Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Welcome to ASR. There are many reviews of audio hardware and expert members to help answer your questions.
Click here to have your audio equipment measured for free!
Yeah that's what I figure. I have no clue how people could say it doesn't get loud enough for them, I feel like how hard these are to drive is really over stated, I can get these loud enough just barely even on low gain.
[TableOfContents] Introduction Design Sound Measurements [End] [YouTube:https://www.youtube.com/watch?v=zWQfadCaAqQ] Introduction Orchard audio is most well known for their class-D speaker amplifiers, but the Valencia offers a departure in both aspects. This is a powerful class AB headphone...
I have a Flux FA-10 Pro that does a great job with the Tungsten and HE6SEv2.
However, I recently purchased an inexpensive banana plug to balanced connector cable from Alibaba to try speaker amp outputs for harder to drive headphones. I am testing an old Krell 300i integrated as a headphone amp via this cable with good results. I am using Roon with a -6db digital preamp output and am quite happy with the results. It would seem that some of these older high powered integrated amps could be a good headphone amp for harder to drive headphones.
Per ChatGPT, the Krell should be able to deliver more than enough power for any headphone:
Given the Krell KAV-300i is rated 150 W into 8 Ω and 300 W into 4 Ω, those two specs imply it’s basically voltage-limited (same max voltage swing), because:
Vrms=P⋅R=150⋅8=1200≈34.64 VV_{\mathrm{rms}}=\sqrt{P\cdot R}=\sqrt{150\cdot 8}=\sqrt{1200}\approx 34.64\text{ V}Vrms=P⋅R=150⋅8=1200≈34.64 V
Check with 4 Ω: 300⋅4=1200≈34.64 V\sqrt{300\cdot 4}=\sqrt{1200}\approx 34.64\text{ V}300⋅4=1200≈34.64 V
So into 155 Ω, assuming it can still swing ~34.64 Vrms:
P=V2R=1200155≈7.74 WP=\frac{V^2}{R}=\frac{1200}{155}\approx 7.74\text{ W}P=RV2=1551200≈7.74 W Answer: ~7.7 watts into 155 Ω (idealized, based on its 8/4-ohm specs).
