little-endian
- Joined
- Apr 16, 2023
- Messages
- 99
- Likes
- 110
Hi Amir,
although it has been discussed here 1, 2 and there, it is undeniable that supporting to deemphasise preemphasised sources for DACs seems to remain a niche topic and annoyingly enough, many, such as the otherwise great Toppings, don't seem to support it.
Neither you so far unfortunately test any DAC for its support in that regard. Given that most devices end up in either the audio performance being above or way above human hearing capabilities, it is however a feature of still way higher magnificence compared to ranting about the last SINAD digit.
Which shows the irony as the public interest of the last point which makes zero difference anyway, is a lot higher than the lack of a feature which when in doubt lets your recordings sound overly bright.
So in short: preemphasis is part of the CD-standard (and even for LaserDiscs!) and thus also S/PDIF and to include a test routine for that shouldn't be a too much of work once established. I guess manufacturers would start to actually give a shit then once Amir says so.
So far, unfortunately only RME seems to do it entirely the right way. Not only do their DACs support it (at least for 44.1/48 kHz), but they also allow to manually enable the deemphasis circuit for sources not aware such as PCs (unfortunately, the PC-support of preemphasised material is also half-assed at best in form of cuesheets).
Please start to test for such details!
Thanks a lot in advance for your consideration.
