You almost never want to fix large dips with EQ, so the issue ~75Hz is going to have to stay. Now, maybe he should have used a higher-Q as to not cause the surrounding region to have a slight dip. The other areas with peaks also are surrounded by areas with dips, so that may be tricky.
Oh, I really like when you start teaching me about room EQ.
I can think of at least 2 options to solve this:
- you can search for a better place to position your speaker
- if you have 1000W amp which you like to mention whenever you can afford to sacrifice 5dB of the headroom to get something like this (same overlay like before but with PIR lowered 5dB). In this scenario you simply attenaute all peaks with adequate Qs and you can actually get something quite close to PIR:
