If you only want to use as a speaker then you could take off the ribbon coming from the mics. Double check the pics from my review, it should be an easy step to do and is reversible too.
I guess this ribbon-bridge should solve it for you, so give it a try, but do remember that you could damage the device while removing the cover or if you are not gentle enough with the wires of ribbons inside!
