restorer-john
I am not sure how to take your comments.
You say it sounds "Poor",. but there was no listening done by you or Amir?
So, Poor based on your expectations, based on Amir's measurements?
Do you not see the the issue with that also....
No issue whatsoever, and you are attempting (poorly) to misquote me.
The performance of the amplifier does not reach the high fidelity bar as far as I am concerned. I listen to repair/restore gear all the time and the HF distortion characteristics of that amplifier are bad enough to be easily audible. The LF response is poor and the HF is a mess.
That's the problem with reviewing bottom of the barrel audio- it normalizes crap performance. Nobody with aspirations to fidelity in audio should even remotely give this a second's consideration. If it was on a free kerbside pickup, I'd leave it there.
