They put out the same power so they should be as loud. Check that you dont have volume limit on. (although if small hands can reach the volume knob you might want to leave this on.) Also turn off auto headroom, unless you think you need it. If room fit is adding a lot of level to the bass, this will also decrease the percieved volume at max power out.The single only difference is it doesn’t get anywhere near as loud as the Yamaha can
You can see the power out level by turning on a meter and setting it to output. If your not hitting zero (max power) you can increase the source input level (up to 10 db) till you get there.
