- Joined
- May 28, 2020
- Messages
- 1,671
- Likes
- 6,571
So, in the last three years I have went from a simple Yamaha AVR using YAPPO for simple distance and level adjustment to a Monoprice HTP-1 using Dirac and really diving into making my own house curve that didn't change the FR of the speakers too much past 500Hz (used the Harman house curve basically with more bass added) to a Trinnov Altitude and using a similar house curve to now an Anthem AVM90 and only using ARC EQ up to 500Hz.
Through them all, I still never felt like my Funk sub was being EQ'ed properly as there was a lot of oomph missing that I knew the sub could produce (being a 21", 2.4kw beast).
Recently I got around to using the Funk subs built-in DSP software and making my own PEQ adjustments to get a flat response: before, there was a +12dB peak between 30-45Hz and a -8dB null between 65-85Hz. The large difference between the two would always have any of the Room EQ software "neutering" the sub and favoring a baseline EQ target that used the peak instead of cutting the peak to get closer to the dip.
What I found doing my own PEQ is I can safely cut the peak and bring up the null for a somewhat flat (+/-4dB) response curve from 15Hz to 100Hz. And using reference level testing material, the sub handles it (no limiting, no distortion, etc).
By and large, the sub/bass sounds the best it ever has in my room with just using PEQ on the sub and letting the speakers play unaltered (no Room EQ). It also helps I have Revel Be speakers for the LCR and a decently treated room, so the natural sound above 200-300Hz is perfect to my ears in my room.
With all that said: am I crazy for completely abandoning Room EQ and letting my speakers play as they are in the room with just simple PEQ adjustment to the sub?
I am even contemplating selling the AVM90 to pocket the funds and just get a simple (but well reviewed) pre-pro or AVR at this point.
Again, crazy?
Again, crazy?
