I think for a good comparison, a flat EQd version would be best.
That's the mathematically clean position, and I don't disagree, sinc reconstruction is the theoretically exact inverse of the band-limited sampling process. What I'm exploring is whether there's a perceptually useful alternative path, similar to how some DACs use minimum-phase or short filters instead of the "correct" linear-phase sinc, trading theoretical perfection for different temporal behavior.IMO the reconstruction method should mirror the sampling method - which is always sinc-based in downsamplers inside the oversampling ADC chips.
foo_abx 2.2.1 report
foobar2000 v2.25.7
2026-03-10 21:30:20
File A: ROYALTY FREE By HilaryDrummer - The Jazz Lounge (Royalty Free Music) - 01 Mellow Mood_composite_4x_flattened.flac
SHA1: c16ae34db66329ab6db72f8cbea36fe00ba942c3
File B: ROYALTY FREE By HilaryDrummer - The Jazz Lounge (Royalty Free Music) - 01 Mellow Mood_sinc_4x.flac
SHA1: 30c48e2a100513ecc51fa5634a613211cff25ab2
Output:
Default : Primary Sound Driver
Crossfading: NO
21:30:20 : Test started.
21:30:47 : Test restarted.
21:30:47 : 00/01
21:31:25 : Test restarted.
21:31:25 : 01/02
21:31:41 : Test restarted.
21:31:41 : 02/03
21:31:56 : Test restarted.
21:31:56 : 03/04
21:32:18 : Test restarted.
21:32:18 : 04/05
21:32:46 : Test restarted.
21:32:46 : 05/06
21:32:59 : Test restarted.
21:32:59 : 06/07
21:33:13 : Test restarted.
21:33:13 : 07/08
21:33:27 : Test restarted.
21:33:27 : 08/09
21:33:38 : Test restarted.
21:33:38 : 09/10
21:33:38 : Test finished.
Total: 9/10
p-value: 0.0107 (1.07%)
-- signature --
0c635fc01092216d4d4b93aedf17b17f3ff48434
A fun exercise
DeltaWave PK Metric is -44.6 dBFS, RMS level is well matched (0.03 dB), peak level shows about 0.13 dB difference. Delta of Spectra shows a small difference in amplitude of about 0.5 dB upwards of 6500 Hz.
Subjective: The composite version has some weird sizzle in the piano notes. Sounds unpleasant to me, but is less objectionable at lower volumes.
| Band | Hz | Delta (dB) |
| Sub-bass | 20–60 | +0.00 |
| Bass | 60–250 | -0.00 |
| Low-mid | 250–2kHz | -0.02 |
| High-mid | 2–6kHz | -0.16 |
| Presence | 6–12kHz | -0.68 |
| Air | 12–20kHz | -0.98 |
| Ultrasonic | >20kHz | +52.32 |
Once the high-frequency content is low-pass filtered, you will still fall into the trap of sinc/ringing.
Any attempt to have both no ringing and band limiting is futile because it is going against mathematics.
In my opinion, your method is an attempt to find another way to "fill in" the high-frequency content above the Nyquist, rather than preserving the mirror image (such as "slow" filter).
@OHtaru @kemmler3D You're both right, of course. Local polynomial interpolation is not band-limited, and yes, the waveform peaks above 20 kHz are real and wouldn't be there with a sinc kernel. No argument on either point.Just looking at the waveforms, all those sharp peaks are a total nightmare. The good news is it's ultrasonics, so not audible, but this looks like truly shocking levels of distortion. When waveforms look like that in the audible band, they also sound like that. Metallic and harsh AF.
What does the impulse response look like when it's filtered back down to 44.1Khz? My gut tells me that like @OHtaru says, this is going to end up not far from where it started.
I think this is a bit of a misunderstanding. There is no post-processing or cleanup when using a regular reconstruction filter. You zero-pad the original stream and pass it through the filter function, that's it. In practical implementations, this is done in a single step numerically. This is no different from the approach of calculating the points between samples by any other method in one step.@OHtaru @kemmler3D You're both right, of course. Local polynomial interpolation is not band-limited, and yes, the waveform peaks above 20 kHz are real and wouldn't be there with a sinc kernel. No argument on either point.
But there's method behind this. What I'm trying to establish is whether upsampling can produce something musically useful entirely through reconstruction, no filtering step at all. The output is a 176.4 kHz file where every original 44.1 kHz sample is passed through exactly, and the interpolated samples (now that I fixed the stupid glitch I produced by being careless) between them are computed from local weighted fits using an 8-point stencil. No post-processing, no cleanup.
Again: The filtering is not an optional step, it is the upsampler. It does stand on its own and (in case of sinc / linear phase fast roll-off) is the mathematically most faithful reconstruction of that signal.Why does that matter? Because if the reconstruction itself is good enough to stand on its own, it opens the door to a different kind of signal processing downstream. You'd have a clean, unfiltered, high-rate signal that you can then EQ, room-correct, or run through any DSP chain without fighting a filter that's already baked in. The filtering becomes a choice you make later, not something the upsampler decided for you.
Well, based on my last ABX before the update, there was a perceptible difference and not for the betterThe specific things I'm trying to find out:
- Whether local reconstruction gives tighter time-domain accuracy on transients than a global sinc kernel, particularly for downstream stereo signal adaptation which could matter for processing like room correction, where time-domain precision is relevant
- Whether busy, contested passages reconstruct more naturally when interpolation only looks at the local neighborhood instead of pulling in distant samples
- Whether having a tunable amount of ultrasonic content (bounded by PNC constraints, not just left wild) is a useful design variable
Whether any of this produces a perceptible difference (or anything I can work with) is genuinely the open question, I don't know yet. But these are the stakes, not experimentation for its own sake.
Ah, this is valuable. You're right, there probably is misunderstanding on my part. I was using "filter" loosely. What I mean is that sinc reconstruction band-limits via a global kernel (well much bigger than mine in any case), and I'm replacing that with a local kernel that doesn't band-limit. Both are actually single-step interpolation, just different kernels and I I was treating band-limiting as filtering, which muddied my framing. Messy terminology on my part.I think this is a bit of a misunderstanding. There is no post-processing or cleanup when using a regular reconstruction filter. You zero-pad the original stream and pass it through the filter function, that's it. In practical implementations, this is done in a single step numerically. This is no different from the approach of calculating the points between samples by any other method in one step.
Just because it's called "filter", it doesn't mean this works like an air filter on a vacuum or something, where the filter is optional but the vacuuming is the goal. Filtering is not a post processing step, it's a convolution of the original signal resulting in an upsampled datastream.
The sizzle and ticks you heard, that could be V1's bug (original samples were being modified, which is fixed in V2), or it could be the DAC reacting to non-bandlimited content as you suggest. I don't hear sizzle on either version on my setup, but different DACs can handle this differently. V2 now passes through every original sample exactly and constrains the interpolated values. I've regenerated the same Jazz Lounge track with V2 if you want to run another ABX, raw output, no EQ flattening, same source file. :Well, based on my last ABX before the update, there was a perceptible difference and not for the better
I am speculating here, but it could be that the sharp peaks in the output cause some form of artifacting when run through a regular DAC using a regular reconstruction filter. Possibly intersample-overs because the waveform is almost "illegal" in parts, specifically because it's not bandlimited. It sounded sizzely with some weird ultrashort ticks in there.
foobar2000 v2.25.7
2026-03-11 15:03:42
File A: V2-ROYALTY FREE By HilaryDrummer - The Jazz Lounge (Royalty Free Music) - 01 Mellow Mood_sinc_4x.flac
File B: V2-ROYALTY FREE By HilaryDrummer - The Jazz Lounge (Royalty Free Music) - 01 Mellow Mood_composite_4x.flac
SHA1: 43545fc7c2e718e9b5c99071493c52692a21942f
Output:
Crossfading: NO
15:03:42 : Test started.
15:04:16 : Test restarted.
15:04:16 : 01/01
15:05:23 : Test restarted.
15:05:23 : 02/02
15:06:04 : Test restarted.
15:06:04 : 02/03
15:06:31 : Test restarted.
15:06:31 : 03/04
15:07:13 : Test restarted.
15:07:13 : 04/05
15:08:22 : Test restarted.
15:08:22 : 05/06
15:08:40 : Test restarted.
15:08:40 : 06/07
15:09:22 : Test restarted.
15:09:22 : 06/08
15:09:36 : Test restarted.
15:09:36 : 07/09
15:09:56 : Test restarted.
15:09:56 : 07/10
15:09:56 : Test finished.
Total: 7/10
p-value: 0.1719 (17.19%)
-- signature --
d38fa518bfa49755a1ef883825739054f34c902c
Significantly more difficult to hear a difference with V2:
I'm pretty sure the small level difference (0.5 dB above 6.5 kHz, about 1 dB at 18 kHz) is what remains audible. You can see from the correct guesses that my ears were getting tired around trial 7 listening for any clues. I think that there is a tiny bit of added sizzle left in the composite version which is just barely audible, but that might be my imagination. As the PK metric of -60.1 dB (average) and -47 dB (peak) shows, the differences are small overall - even a good loopback recording only hits an average of about -80 dB. The DW Spectrum of Delta is below -83 dB for the full range.
That being said, if it ends up sounding the same but comes with a lot of ultrasonic stuff potentially causing problems like IMD in some setups, why risk using it?
Here's the 19 kHz sine as promised. As expected, near-Nyquist single tones are where polynomial interpolation is weakest and sinc is exact by definition. Plot + files attached.Well, let’s see that… reconstruct a 19 kHz sine please!
Yes, for every frequency until very close to fs/2.sinc is exact by definition
Your sinc result is actually quite poor, btw.
I have managed to implement @RandomEar sinc lin-fast 512-tap filter as the comparison baseline. Coefficients are natively designed for 8x, so I zero-stuff by 8, convolve, and decimate by 2 to get the 4x output. Should be faithful to the filter's intended operation if I did this right.Coefficients are attached.
