Alsozone /3e Audio GaN Monoblocks | New Comer
Interesting they announced it in the same month XINBAOSHENG AUDIO EQUIPMENT said good bye to GaN and hello to silicium carbid.
Forgot to add....
We want to avoid this before you start the project )
And when external psu are a given, it's time to offer cabling options and not just brick after brick with the units.
2 x mono can be powered by one 48v10a psu which can be y-split. Just need proper cables and connectors for these power ratings.
Product courtesy of Fosi.
The FOSI pack is a bit unusual because the Y-split is handled via a noise reducer.
Returning to the original topic—designing a GaN amplifier—we specifically want to avoid having the PSU unit be bulkier than the amplifier units; otherwise, the marketing argument for GaN loses its real significance...
The issue with most of the GaN amps on the market is the lack of post filter feedback and their load dependent frequency response. Mostly the use of GaN fets has been a marketing ploy and nearly all of the GaN based amps are second rate in measured performance compared to the state of the art class d like Purifi or Hypex.
It is really strange that one of the most important differences is completely omitted from the table.
Significantly lower efficiency—often even (significantly) worse than SiC—when dealing with rapid fluctuations in power output. The more frequent the fluctuations, the worse it gets.
A good thing that this isn't an issue for an audio amplifier (where is the sarcasm emoji when you need it?).
Interesting... if I may weigh in: I would start by reasoning in reverse—avoiding this below approach—based on what we know about GaN amplifiers:
Avoid this :
Avoid this :
Use this as reference
Measurements :
And really read this about GaN
There was an interview with B. Putzeys about GaN.
Sorry, I've lost the URL.
Bruno Putzeys was
What's your take on this based on those interviews and posts?
IIRC, GaN would be interesting only for high power.
This has nothing to do with high power output; otherwise, GaN wouldn't be so successful in small power adapters rated at 20, 30, 45, 60, or 65 watts, etc.
GaN’s advantages really come into play under steady, consistent loads.
The more the load fluctuates, the more GaN’s efficiency and advantages diminish—potentially even dropping below the levels of conventional technology.
And what kind of load do audio amplifiers present?
Current shown price:
1 x GaN Amp with 48v 5a PSU: $ 129.99
2 x GaN Amps (no PSU): $ 198.99
It is unusual for 3E Audio to publish so few measurements.
What is available looks a lot like the ACM8816 to me.
Independent tests will show whether they deserve congratulations for it.
We can ask for measurements if they have already.
@3eaudio
Do you have AP (at least SINAD and frequency response) measurements available to share?
I will never understand the point in having monoblocks with a shared power supply. It's just good old dual mono in seperate boxes. The whole point of monoblocks is having seperate power supplies per channel.
Definitely—sharing power supplies between monoblocks is absolute nonsense and serves only to cut costs.
The whole point of a true mono configuration is complete channel separation and the elimination of mutual interference.
With a shared power supply, channel separation decreases; this can alter the soundstage (or whatever term one prefers) and the overall listening experience to varying degrees.
It is easily measurable and demonstrable that a strong bass impulse in one channel can cause a measurable difference in the output of the other channel when a shared power supply is used.
While this might not necessarily be audible, it does result in a deviation from the source material.
What makes me doubt it is that the ACM8816 GaN chip is a digital chip, whereas the new AlsoZone monoblock is not...
I started a thread here about the latest Dual Mono GaN amp based on the ACM8816; you'll see that it's like an FDA.
It’s hard to say without actual picture, but one could imagine the TI-LMG2100R044 or even the EPC2152... who knows...
In the below pictures, on the left you have the Gan Dual Mono amplifier I discussed in my thread, based on two ACM8816 Mono chips, and on the right the famous Starkrimson Gan with an analog input, the latter features 100% analog modulation (PDM) and a full-bridge power stage based on Infineon gallium nitride power transistors.
The mentioning of "Samplerate: 24bit/48khz" on the datasheet above made me wonder what it's about.
The term "HEMT," the exclusive 1% THD specification, the 108 dB SNR, and the 24–48 volt range all looked very familiar to me.
And why does 3E Audio specify a sample rate of 24-bit/48 kHz?
But, of course, I could be mistaken.
For now, the information is too vague... but we know it is a full-bridge (BTL – Bridge-Tied Load) Class D amplifier featuring a PWM controller and an output stage based on GaN HEMT transistors.
