As promised from another thread, am starting this thread to fact check a contention that Y caps cause audio problems (notably as applied in AC inlet filters) and that noted designer Bruno Putzeys had stated as such. Have seen this contention perpetuated here and on other sites and so would like to see if ASR experts agree or not (about Y cap application).
Here is some background from other sites on this contention...
Here is one notable Bruno P quote from diyaudio.com:
“Y caps: as have been noted, they capacitively couple the mains to chassis. In AES48 compliant balanced systems this is no problem because they keep signal and ground well separated. In an unbalanced system the leakage current will also flow through the ground wire or shield of your $$$$$ RCA interlink and thus add noise to the audio.
As such, Y caps are difficult to avoid, they serve a purpose after all (to keep rubbish generated inside the box from getting out), but what it means is that it pays to try minimizing them. There are small Y caps in the SMPS600. Since they wholly suffice, there is no reason to compound them with external ones.”
If you look around, he talks about Y caps in many contexts. Notably both in a SMPS and in an AC inlet filter.
Here is another (even older) quote from Audioholics and appears to be the source of the confusion…
Bruno continues: "The difficulty lies in the fact that life isn't getting easier in the future. Switch-mode power supplies suffer an aggravated version of interwinding coupling across the transformer. The circulating current between the primary and secondary sides is quenched by placing a so-called "Y" capacitor between primary "ground" and secondary ground. This reduces the voltage imposed by the transformer between the two sides by a factor equal to the ratio between Y capacitance and parasitic capacitance between the windings. Increasing the Y cap reduces the problem, but never solves it. Worse still, the Y cap effectively connects the AC line to the audio ground! Similarly, other EMI problems are "fixed" by connecting caps to chassis everywhere. Y caps are also found sometimes in audio equipment that has a linear supply and a good reputation. They are also part of mains filters, devices often used as a selling argument in the audio world (cleaner mains! sure! but the dirt is now in your audio).
Such practices are of course of no consequence in computers and copiers, VCRs and TVs (when not connected to the audio system). Unfortunately the same people who have been smart enough to design these are now selling power supplies for use in DVD players etc.
Designing a Switch-mode power supply that does not create circulating currents and that does not need Y caps is certainly possible. I am afraid, however, that the number of designers worldwide capable of pulling this off can be counted on one hand, and they might not even actually be at it."
So, at the end of the first paragraph, Bruno is quoted as saying “They (Y caps) are also part of mains filters, devices often used as a selling argument in the audio world (cleaner mains! sure! but the dirt is now in your audio).” So this states exactly what has been circulating around regarding EMI inlet filters. Given the earlier quote, not sure how this “dirt” gets in the audio single or maybe he was misquoted? He is not hanging around diyaudio anymore and that, for unbalanced system, Bruno does mention leakage current as source of the noise.
Agree or disagree? Does seem clear that Bruno (on 2 different occasions) contends that Y caps can cause noise. I have measured a few Hypex that used inlet filter with Y caps and did not find any major issue but perhaps I missed something?
Please help!
Please help!
for security reasons. The bleed resistor is for discharging if unplugging to avoid possible el. shock.
