If there is no audible difference (there isn't) and the chip itself is invisible inside the case, how could it be worth any additional expense? Outside of a couple of edge cases where the op amp is incompatible with the circuit causing extreme distortion or oscillations, op amps do not audibly alter the sound of an amp [
1,
2,
3]. You can build transparent amplifiers using dirt cheap NE5532s - outside of a very narrow band of "you're getting nothing but fake chips for this kind of money", the price of op amps does not relate to their sound quality.
Power supplies or amplifier classes do not have any "sound". You do not listen to your PSU, you listen to rectified, filtered DC which is being modulated. Unless you do proper, controlled testing (level-matched, blind), all you report on is your own
cognitive bias. Essentially, our brain tells us that it heard something, but it's simply making it up.
