Just received my Cymax CY-1ET6525SA-02 Power Amplifier. Price delivered to my door including VAT is similar to the Audiophonics HPA-S450ET. Sound quality through my Lintons is impossible to distinguish. The Purifi 1ET6525SA modules sound just as transparent and powerful on both as expected, but the gain settings are a bit different, 20 dB on the Audiophonics buffer board (with OPA1656) is enough to max out the effect of the power modules at @ estimated 1% THD. On the Cymax you have to set the gain higher at 23.3 dB or a even at 26.3 to get the same effect out of the speakers (with OPA1612). A bit strange, must mean the the Cymax implementation (buffer board) "eats" more gain on the way to the Purifi modules. Or is it the different op amps causing this?
Cymax build quality seems very nice and with a very heavy case, 13 kg versus just 4 kg for the Audiophonics. The weight is not very important in my opinion. The big difference is in height. Cymax is quite a lot taller and take more room in your rack. The power on static noise is maybe a microscopic level lower on the Cymax, but that might just be a coincidence from every power-on cycle. The one great feature I find much better on the Cymax is the front LCD control knob. It's great that you can control all setting from this easy to use button instead of switch buttons on the underside and back. Very nice! There is also two sets of (30W) linear op amps power supplies included in the Cymax but I can't hear any difference with these compared to the Audiophonics without these.
When it comes to warranty, and ease of return, you might go for Apollon or Audiophonics if you live in Europe. Sending the Cymax back to Hong Kong might be troublesome.
I have included some pictures of the internals if you like to take a peek. But all in all, the Cymax is similar in quality to the Audiophonics model, and even more convenient when it comes to the input control button.
ThanksPretty neutral or transparent I would say. That does not mean boring, but natural and with good presentation of sounds throughout the whole frequency spectrum, minus 1 kHz that needs a little EQ boost. Just the way the Lintons sound as you can see in the measurements from Erin’s Audio Corner. The Purifi 1ET6525SA have more than enough gain amplification to make the Lintons sing loud and clear if you like wide sound dispersion. I do, but you might like something else, as Erin would say. Your listening room and speakers will determine your sound reproduction and the Purifi class D modules will guarantee that the power (gain) amplification will NEVER be the bottleneck.
Why?I have sparkos 2590 opamps already in hand I can install
There is nothing revolutionary with this setup. The 1 and 2 from the "system advantages" are hypothesis that need confirmation by measurements especially because we have no idea of the E50 behavior when loaded by a relatively small impedance (buffer bypass).Really interesting how you have your chain set up with digital volume control and the DAC's super high output getting sent straight to the amplifier module without needing a buffer in the way! They should come up with a cool name for it! Are you able to arrange the gain/output levels so that you can minimize the digital attenuation needed? or are you not too concerned with digital attenuation? This seems like it would be really great for a near field setup where room correction is less necessary. Although in my corner desk setup, I have seen some benefit to dirac when I used it.
Unrelated news: My 6525 amplifier is delayed one week as they found a minor flaw in the latest batch of buffer boards and offered to send me the manually fixed boards now or let me wait a week for perfect new boards. I chose to wait a week. The fact that they told me about the flaw, I consider a sign of honesty and great service.
edit: oh I'm dumb, I see now from your chart that the purifi amplifier modules have a low 12.3db gain when bypassing buffer boards and feeding the dac straight into them.. that WOULD allow you to minimize digital attenuation required.. wow this is really something to consider
Since we do not know the behavior of the E50 under load, this is unfortunately not a fact.the fact remains that the Topping E50 II can output pro-level 11.3Vrms/23.2dBu@0dBFS with a SNR at 131dB@1kHz which is perfect for running the Purifi-modules without buffers/op-amps
